2 koralias
Posted: Fri Apr 19, 2013 7:21 pm
by Rodasphoto
I used the wizard and programmed them both as random wave makers but one only get switched on. Is there a limitation on how many power heads I can set to wave maker? If there is what do I do with the second one to make it come on randomly?
Re: 2 koralias
Posted: Fri Apr 19, 2013 8:44 pm
Can you post your code?
Re: 2 koralias
Posted: Sat Apr 20, 2013 7:58 pm
by Rodasphoto
    ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardLights( Port2,9,0,21,5 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(8,30,20,30,15,100,15) );
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
Re: 2 koralias
Posted: Sat Apr 20, 2013 7:59 pm
Try this instead:
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,60,100 );
Re: 2 koralias
Posted: Sun Apr 21, 2013 3:52 pm
by Rodasphoto
That seems to work. Weird because I used the wizard I used the wizard and thought it would do this automatically. Thanks for the help.
Re: 2 koralias
Posted: Tue Oct 08, 2013 12:08 pm
by Bruz4023
i know this is old and dead but i want to revive it temporarily!
I have 2 koralias and i was wondering if you are just switching them on and off with the relays, or do you have fancier ones you can control the speed of? I just ordered so i havent played with anything yet!
The reason i ask is dont they reverse their direction often? Or just click loudly?
Re: 2 koralias
Posted: Tue Oct 08, 2013 1:26 pm
Only on and off. Direction reversing is a hit or miss issue from what I've heard
Re: 2 koralias
Posted: Tue Oct 08, 2013 1:32 pm
Mine spins backwards all the time.
One of them is even dead and inside the tank with its power plug disconnected :(
Worse is that I have 2x WP-25 (controllable Jebao pumps) brand new in the box waiting to be hooked up and I'm too lazy and out of time to do it... :oops:
Re: 2 koralias
Posted: Tue Oct 08, 2013 6:01 pm
by binder
rimai wrote:Mine spins backwards all the time.
yeah, mine would get screwed up too.
oh and I have a wp-40 that im too lazy to hook up as well. I feel your pain.
Sent from my Nexus 7
Re: 2 koralias
Posted: Wed Oct 09, 2013 7:51 pm
by johniii
If your koralias spin backwards email hydor they will send you the stuff to fix it plus extra parts. They don't even ask the age.
Sent from my XT912 using Tapatalk 4
Re: 2 koralias
Posted: Thu Oct 10, 2013 10:01 am
by Bruz4023
ok because that is what mine do too!
hey if you to lazy to hook up that wp-40 i could take it off your hands i have been looking for one! probably one or two wp-25s would be better for my tank
Re: 2 koralias
Posted: Thu Oct 10, 2013 7:11 pm
by binder
Bruz4023 wrote:ok because that is what mine do too!
i plan on setting it up next week. that's one of my tasks for my vacation. :)
Re: 2 koralias
Posted: Sat Oct 12, 2013 11:00 am
by Rodasphoto
When I purchased mine they were the updated ones and do not spin backwards. I really have to listen carefully to hear that they come on.
