Set wave speed based on feeding mode?
Smotz
Post by Smotz »
I am looking to keep my wave pump (WP-40) but set it to a steady 35 during feeding mode.
Can someone assist?
Also, how do I rename the ports in the code - instead of "Port1", etc?
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardATO( Port2 );
    ReefAngel.PWM.SetDaylight( LongPulseMode(35,60,5,false));
    ReefAngel.PWM.SetActinic( LongPulseMode(40,75,4,false));
    ReefAngel.Portal( "Smotz" );
    int x,y;
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
////  Wave Modes
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
Here's how to define the ports:
#define Heater Port1
And I added the if statement if your in feeding mode to set the wp40 to 35%
    If (ReefAngel.DisplayedMenu==FEEDING_MODE) {
       ReefAngel.PWM.SetDaylight(35);
       ReefAngel.PWM.SetActinic(35);
Smotz
Re: Set wave speed based on feeding mode?
Post by Smotz »
Nice!
I saw a code that turned off the skimmer if the return pump was off. I would like to do the same for my skimmer and reactor pump? Got some magic for that?
This is what I use..
// Turn off Skimmer if Return pump has been shutoff.
if (bitRead(ReefAngel.Relay.RelayMaskOff,ReturnBit)==0) {
bitClear(ReefAngel.Relay.RelayMaskOff,SkimmerBit);
I have ReturnBit and SkimmerBit #defined so keep in mind the actual value is port# minus 1.
Smotz
Post by Smotz »
lnevo wrote:This is what I use..
So lets say your skimmer is on port 1 and your return is on port 2 - then skimmerbit=1 and returnbit=2 ? Are they just variables to represent the port?
These are my declarations:
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define Fugelight Port8
Smotz
Post by Smotz »
lnevo wrote:Here's how to define the ports:
I am getting this error when using the above code - any thoughts?
Display_Tank_adjusted_ino.cpp: In function 'void loop()':
Display_Tank_adjusted_ino:99: error: 'If' was not declared in this scope
Display_Tank_adjusted_ino:99: error: expected `;' before '{' token
Display_Tank_adjusted_ino:102: error: 'else' without a previous 'if'
The If somehow got capitalized...
As far as the SkimmerBit and the ReturnBit
No, SkimmerBit = 0 and ReturnBit = 1... Since the Port #'s are 1-8 and the bit that represents them are 0-7..
So...
For you I would use:
#define Skimmer 3
#define Return 4
Also, don't you only have one WP40? If so then you don't have to run the functions for Actinic and for Daylight, you can remove the one you aren't using... unless you want them both for future :)
The error code tells a lot about what it is wrong...
The error is on line 99, which is show on green above.
It's complaining about "If", which is in red above. The reason it is complaining is because everything is case sensitive, which means If is difference than if.
Try changing it to if (all lowercase) instead.
Smotz
Post by Smotz »
Thank you all!
Smotz
Post by Smotz »
lnevo wrote:Also, don't you only have one WP40? If so then you don't have to run the functions for Actinic and for Daylight, you can remove the one you aren't using... unless you want them both for future :)
I actually changed the code to leave 1 on 100% for testing purposes
