Trying to set multiple on off times for 1 port
Posted: Sat Apr 27, 2013 6:50 am
Hello,
Total newbie here.
I've been looking for a simple way to turn my Kalk reactor on and off a couple times a day. I tried the standard lights but this only allows one on/off time.
Is there a simple way to do this?
Here's the code that I've come up with so far.
Total newbie here.
ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.StandardLights( Port1,22,30,13,30 ); //*sump fuge light
ReefAngel.StandardLights( Port2,13,30,22,30 ); //*top fuge light
ReefAngel.StandardLights( Port3,13,30,22,30 ); //*Actinic
ReefAngel.StandardLights( Port4,13,30,22,30 ); //*Daylight
ReefAngel.StandardLights( Port5,0,0,0,1 ); //*kalk reactor
ReefAngel.StandardATO( Port6,6000 ); //*Fresh water solenoid
ReefAngel.StandardHeater( Port7,775,785 );
ReefAngel.StandardLights( Port8,13,30,22,30 ); //*Light fan
ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,30,5,60,30,5) );
ReefAngel.PWM.SetActinic( PWMSlope(13,30,22,30,5,70,30,5) );
byte x;
byte y = 2;
char text[7];
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Gonzo's Reef"); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
x = 12;
y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, COLOR_BLACK, x, y, text); // Draw the temperature, white numbers on a colored background
x += (16*4) + 8;
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
// Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
