Return Pump and Float Switches
Posted: Sat Apr 27, 2013 8:53 am
I have ATO low set as my topoff control. It turns on a AquaLifter whenever the level drops.
I have the Hi ATO as a cutoff for my return pump. Currently, if the level drops, the return pump switches off until the switch is lifted again.
What I would like is for the return pump to shut off when the sump level is low, but not switch back on until the topoff switch is activated. I can't seem to figure out the logic.
Any ideas?
Any ideas?
