Updating to 1.0.4 - Missing Green.h
phrusher
Post by phrusher »
Hi,
I get an exception when updating from 1.0.3 to 1.0.4 at around 67%. Same thing when running the update utility but that also reports red.h as not found. Even though the update fails the version number is changed so the libraries version reports 1.0.4.
Other than that it looks like a great update so I'm looking forward to try it out :)
Updating /libraries/ReefTouch/Green.h
java.io.FileNotFoundException: https://raw.github.com/reefangel/libraries/master/ReefTouch/Green.h
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1311)
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:234)
	at java.net.URL.openStream(URL.java:1010)
	at processing.app.UpdateCheck$DownloadFile.copyURLtoFile(UpdateCheck.java:274)
	at processing.app.UpdateCheck$DownloadFile.run(UpdateCheck.java:243)
	at java.lang.Thread.run(Thread.java:619)
Exception in thread "Thread-5" java.lang.NullPointerException
	at sun.nio.ch.FileChannelImpl.transferFrom(FileChannelImpl.java:591)
	at processing.app.UpdateCheck$DownloadFile.copyURLtoFile(UpdateCheck.java:287)
Re: Updating to 1.0.4 - Missing Green.h
Thanks for reporting. I'll check and get back
Try it now.
You may need to change preferences.txt file to trigger the auto-update again.
http://arduino.cc/en/Hacking/Preferences
Also, change the libs version to 1.0.3 on ReefAngel.h
phrusher
Post by phrusher »
No its working from within the Arduino studio but the RA Update Utility is still looking for ReefTouch/Green.h and Red.h.
That update utility is deprecated :(
phrusher
Post by phrusher »
Ah, ok. Guess I have an old installation then :) I'll try and keep that in mind.
