trouble with pwmslope
Posted: Sun Apr 28, 2013 7:57 pm
by duck
Im using the cloud effects from the sticky thread, and cut and pasted. I dont know what values to edit to give it more time.. My lights go from 14 to 100 % in about 2 minutes. Heres the code. Any ideas?
    byte ActinicPWMValue=0;
    byte DaylightPWMValue=0;
    //Return              1
    //Blue LED and Fans   2
    //White LED           3
    //Alk                 4
    //Powerhead           5
    //Heater              6
    #define ATO           7
    //Skimmer             8
    #define wifi
    ReefAngel.PHMin=200;
    ReefAngel.PHMax=807;
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
      ReefAngel.StandardLights( Port2,9,0,21,0 );
      ReefAngel.StandardLights( Port3,9,0,21,0 );
      ReefAngel.StandardHeater( Port6,760,770 );
      ActinicPWMValue=PWMSlope(9,0,21,0,14,100,14,ActinicPWMValue);
      DaylightPWMValue=PWMSlope(9,0,21,0,14,100,14,DaylightPWMValue);
      CheckCloud();
      //Alk Dosing Pump 1 Minute Every 45 Minutes
      if (now()%2700<60) ReefAngel.Relay.On(Port4); else ReefAngel.Relay.Off(Port4);
      //Powerhead On Every 4 Hours With 30 Min Pause
      if (now()%1800<12600) ReefAngel.Relay.On(Port5); else ReefAngel.Relay.Off(Port5);
      //Heater Control on at 77F and off at 78F
      ReefAngel.StandardHeater(Port6,770,780);
      ReefAngel.SingleATO(true,ATO,300,0);
    void CheckCloud()
    #define Clouds_Every_X_Days 2
      // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 15
    #define Min_Clouds_per_Day 3
    #define Max_Clouds_per_Day 5
    #define Lightning_Change_per_Cloud 50
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
    #ifdef forcecloudcalculation
        if (cloudchance==255)
    #else
    #endif
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
            else lightningstatus=0;
            if (lightningstatus)
              DaylightPWMValue=100;
              ActinicPWMValue=100;
              DaylightPWMValue=0;
              ActinicPWMValue=0;
            delay(1);
          cloudindex++;
          if (cloudindex < numclouds)
          int x=0;
        if (lightningchance)
          int x=0;
      cstart*=60;
      cend*=60;
      if (n>cend) return PWMStart;
Re: trouble with pwmslope
Posted: Sun Apr 28, 2013 8:08 pm
Looks ok, except for:
It needs to be the last line inside the loop() section, right below the SingleATO.
Posted: Mon May 13, 2013 11:06 am
by ufgators2k
Is there library that includes the cloud functions or is it best to leave it in the main code?
Posted: Mon May 13, 2013 12:36 pm
Not yet... I know rufessor is working on a weather package, but it's still a bit from release.
