multiple wave pattern
Posted: Mon Apr 29, 2013 7:05 pm
by SaltyGXP
OK so I inserted some wave pattern codes does this look right? I'm not sure if there needs to be something in the void setup or void loop section or not. If so can you help me with that? The Things I added or changed are in bold
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,22,0 );
ReefAngel.StandardLights( Port2,10,45,21,15 );
ReefAngel.StandardLights( Port3,11,15,20,45 );
ReefAngel.StandardLights( Port4,22,0,2,0 );
ReefAngel.StandardHeater( Port5,775,780 );
ReefAngel.Relay.DelayedOn( Port6,5 );
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
{ if (hour()>=10 && hour()<14)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,60);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
else (hour()>=14:01 && hour()<22)
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
double x,y;
x=double(now()%(PulseDuration));
x/=PulseDuration;
x*=2.0*PI;
if (!PulseSync) x+=PI; // shift the sine wave for the right pump
y=sin(x);// y is now between -1 and 1
y+=1.0; // y is now between 0 and 2
y/=2.0; // y is now between 0 and 1
// now compute the tunze speed
y*=double(PulseMaxSpeed-PulseMinSpeed);
y+=double(PulseMinSpeed);
y+=0.5; // for proper rounding
// y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
return constrain(byte(y),25,60);
ReefAngel.Portal( "saltygxp" );
Posted: Mon Apr 29, 2013 7:17 pm
No...it doesnt work that way...
First off you cant have a function (ie ReefCrestMode() ) inside another function (ie loop() )
Also the wave modes are now part of the libraries. Also you have to set a port that you want to use with the result of your wavefunction...
So look up some of the examples that have been posted..there is a tutorial posted as well and try again..
Im sure someone can post something here as well but on my phone right now..
Re: multiple wave pattern
Posted: Mon Apr 29, 2013 10:37 pm
by SaltyGXP
lnevo wrote:No...it doesnt work that way...
So.........After 3 hours of reading and doing the same thing wrong 100 times I figured it out lol. When you said the wave functions were part of the libraries I was thinking you were talking about the Sketch Book example codes. So now that I figured it out here is what I have come up with. I'm hoping what I have done is right lol.
ReefAngel.WaterChangePorts = Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.StandardHeater( Port5 );
if (hour()>=10,01 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% +/- 20% on sync mode
else if (hour()>=12,01 && hour()<12,11)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
else if (hour()>=12,12 && hour()<14,12)
else if (hour()>=14,13 && hour()<18)
ReefAngel.PWM.SetDaylight( SineMode(20,45,30,true) );
else if (hour()>=18,01 && hour()<18,11)
else if (hour()>=18,12 && hour()<22)
ReefAngel.PWM.SetDaylight(SineMode(20,45,30,true) );
else if (hour()>=22,01 && hour ()<10)
ReefAngel.PWM.SetDaylight( LongPulseMode(15,35,120,true) );
Posted: Tue Apr 30, 2013 4:14 am
Better. But your if statements are wrong. You can't have hour()>=18,01 like that..you'd have to do hour() && minute() comparison...
Posted: Tue Apr 30, 2013 7:31 am
by SaltyGXP
lnevo wrote:Better. But your if statements are wrong. You can't have hour()>=18,01 like that..you'd have to do hour() && minute() comparison...
OK so I'm pretty sure this isn't what you are talking about. can you give me an example please. I searched and cant find anything or i missed it. thanks very much for your help Inevo.
if (hour()>=10 && minute()<01) && hour()<12)
Posted: Tue Apr 30, 2013 7:35 am
You don't even need the minute in that statement...
if (hour()>=10) && hour()<12)
That will run from 10:00-11:59
Posted: Tue Apr 30, 2013 7:40 am
by SaltyGXP
The reason I was using minutes in there is because I only want NutrientTransportMode to run for 10 minutes at a time.
Posted: Tue Apr 30, 2013 7:56 am
Use like this then:
if (hour()>=10) && hour()<12 && minute()<=10)
I think this would do 10:00 to 10:10 and 11:00 to 11:10
Is it what you wanted?
Posted: Tue Apr 30, 2013 8:00 am
Just a heads up too....
NTM is a mode that takes about 2.5 hours to complete.
The first 45min, it is nothing more than short pulses.
So, 10 minutes of NTM is not going to give you any more than short pulses
Posted: Tue Apr 30, 2013 8:06 am
by SaltyGXP
rimai wrote:Just a heads up too....
I didn't know that lol.....I'll change it then :mrgreen:
Posted: Tue Apr 30, 2013 12:28 pm
by SaltyGXP
Ok so heres what Ive got. I added Port 8 to the feed mode aswell so the jebao will shut down during feedings.
ReefAngel.FeedingModePorts = Port8Bit;
if (hour()>=10 && hour()<16)
else if (hour()>=16 && hour()<19)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,5000,true) );
else if (hour()>=19 && hour()<22)
else if (hour()>=22 && hour()<10)
Posted: Tue Apr 30, 2013 1:10 pm
This one wont' ever work...
You can't have the hour be greater than 22 AND less than 10... Change the && to || for an OR.
Posted: Tue Apr 30, 2013 1:11 pm
Your other option instead of changing the statement is to just remove it so that your last IF test is just an else... this way it becomes the default if none of your other tests qualify.
Posted: Tue Apr 30, 2013 1:26 pm
by SaltyGXP
lnevo wrote:Your other option instead of changing the statement is to just remove it so that your last IF test is just an else... this way it becomes the default if none of your other tests qualify.
so like this?
Posted: Tue Apr 30, 2013 4:54 pm
Looks good!!!
Posted: Tue Apr 30, 2013 5:24 pm
by SaltyGXP
lnevo wrote:Looks good!!!
I can't thank you enough for all your help and fast reply's thanks so much. :mrgreen:
Posted: Sat May 11, 2013 9:50 pm
by dapg8gt
Thanks for this thread it opened up A little more what I need to know to do what I need to do with my jebaos. Can you break down what exactly the code you wrote is doing at what times so I can get a better idea of what to do in my situation thanks.
For night mode can I just add a constant mode with speed low for lights off hours?
Posted: Sun May 12, 2013 1:49 pm
by SaltyGXP
dapg8gt wrote:Thanks for this thread it opened up A little more what I need to know to do what I need to do with my jebaos. Can you break down what exactly the code you wrote is doing at what times so I can get a better idea of what to do in my situation thanks.
// this will allow reefcrest to run from 10-4
// here it's going to run NTP from 4-7 it takes two hrs to complet NTP
// it will run Sine for the last 3hr of my lighting period
// here it will run a lower sine mode until the lights turn back on. There is no time need because I used Else
ReefAngel.PWM.SetDaylight(SineMode(15,30,120,true) );
