Single ATO with timer?
Posted: Wed May 01, 2013 12:36 pm
by Smotz
Hi All -
Can anyone advise how to code a single ATO to stay turned on for say 2 minutes then disengage?
Re: Single ATO with timer?
Posted: Wed May 01, 2013 12:41 pm
Huh?
If it turns off, when would it turn back on?
Are you talking about timeout?
Sent from my Galaxy S3 using Tapatalk 2
Posted: Wed May 01, 2013 4:45 pm
by Smotz
rimai wrote:Huh?
Sorry, guess I didn't explain it well.
I would like the ato to be engaged when the single float switch activates and then simply turn off after X amount of time ( 2 minutes ).
Posted: Wed May 01, 2013 5:29 pm
Turn off after 2 minutes even if the water goes past the float, is that correct?
Posted: Wed May 01, 2013 5:41 pm
by Smotz
rimai wrote:Turn off after 2 minutes even if the water goes past the float, is that correct?
Yes. With a single, it will go past the float. After a bit I will be able to determine exactly how much time is needed to get the refill where I want it.
Posted: Wed May 01, 2013 5:50 pm
Try this:
On setup():
ReefAngel.Timer[1].SetInterval(120);
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port1);
if (ReefAngel.Timer[1].IsTriggered())
  ReefAngel.Relay.Off(Port1);
Posted: Wed May 01, 2013 6:02 pm
by Smotz
rimai wrote:Try this:
On setup():
Thanks Roberto - so I understand:
I would change "Port1" to whatever port my ATO pump is on - correct?
The setInterval(120) is 120 seconds - correct?
I can change "Timer[1]" to whatever I want to call the function?
Posted: Wed May 01, 2013 7:12 pm
Yes, change the port to whatever you want, but keep Timer[1]. This is an internal timer.
Posted: Thu May 02, 2013 4:17 pm
by Smotz
rimai wrote:Yes, change the port to whatever you want, but keep Timer[1]. This is an internal timer.
Roberto - I found a flaw in my logic:
This 'single ATO with timer' will work with the exception of if the water runs out in the reservoir. Then the float would immediately reactivate for the duration of the timer, then reactivate again, and again..
Can you think of anything to prevent this?
Posted: Thu May 02, 2013 4:46 pm
I would add a check for what time the last run was and if it was right after the runtime of your ato then set the relay mask off for the device and maybe set a portal variable that you can trigger a txt message. This way you can reset the mask once you see whats wrong and it will keep your ato pump from burning out.
Posted: Thu May 02, 2013 4:59 pm
I'll try throw some code together by tomorrow.,
Posted: Thu May 02, 2013 5:08 pm
by Smotz
lnevo wrote:I would add a check for what time the last run was and if it was right after the runtime of your ato then set the relay mask off for the device and maybe set a portal variable that you can trigger a txt message. This way you can reset the mask once you see whats wrong and it will keep your ato pump from burning out.
yea, thats what I would do too. :roll:
Posted: Thu May 02, 2013 5:09 pm
by Smotz
lnevo wrote:I'll try throw some code together by tomorrow.,
Much appreciated
Posted: Fri May 03, 2013 12:38 pm
Ok, trickier than I thought it would be, but just need to wrap my head around it... sorry it took so long.
It should be clear how the logic works, but let me know if any questions.
If someone wants to copy this, keep in mind the mask code needs to be adjusted if your ATO is on a relay expansion box.
  // Define these for your preference
  byte floatThreshold=30; // How soon is too soon?
  byte ATOPort=Port1; // Made this a variable so we can change it in one spot
  int runtime=240; // Replaces the Timer[1].SetInterval
  // startTime replaces Timer[1] and endTime added to track last run
  static time_t startTime, endTime;
  static boolean atoRunning;
  if (ReefAngel.LowATO.IsActive()) // Float switch is active.
    startTime=now(); // Time to start
    if (startTime()-endTime() < floatThreshold) // Has enough time passed since the last run?
      bitClear(ReefAngel.Relay.RelayMaskOff,ATOPort-1); // Set off mask to disable the relay
  if (now()-startTime < runTime) // Are we within the runTime
    ReefAngel.Relay.On(ATOPort);
    atoRunning=true;
  else // runTime is over
    ReefAngel.Relay.Off(ATOPort);
    if (atoRunning) {
      endTime=now();
      atoRunning=false;
  // Assign custom variable to value of the off mask
  // Default is 1 for off mask so setup the alert if value is < 1
  ReefAngel.CustomVars[0]=bitRead(ReefAngel.Relay.RelayMaskOff,ATOPort-1);
  // Dummy variable to keep portal feature activated (may not be necessary...)
  ReefAngel.CustomVars[7]=255;
Posted: Fri May 03, 2013 1:53 pm
by Smotz
lnevo wrote:Ok, trickier than I thought it would be, but just need to wrap my head around it... sorry it took so long.
    atoRunning=true;
    if (atoRunning) {
      endTime=now();
      atoRunning=false;
Nice - I will give this a try - thank you so much!
