RA jebao harness
Posted: Thu May 02, 2013 5:08 pm
by SaltyGXP
Befor I got my RA I had an Apex so I modded the jebao to work with the Apex. In doing so I cut the wall wart plug thar hooked to the jebao controller. So now I need to solder the jebao wall wart cable to the RA cable pcb . My issue is not knowing weather the jebao cable is center + outer - or center - and outer +. Also what's + and - on the pcb.
Dustin
Re: RA jebao harness
Posted: Thu May 02, 2013 5:25 pm
Center positive
Posted: Thu May 02, 2013 5:47 pm
by SaltyGXP
rimai wrote:Center positive
Sweet thanks rimai! Any ideas on which spot on the pcb is + and -?
Posted: Thu May 02, 2013 5:49 pm
by SaltyGXP
Nvm I got it
