Display freeze
Elevatorguy1
Display freeze
Post by Elevatorguy1 »
Hello,
Just got my RA up and running on my tank and have a problem with the display. Within the first hour of it running the display froze. I could see the info on the display but could not get to the main menu. I unplugged the head unit and plugged it back in and all was normal. Temp, PH and time were updated. Then before the lights turned off the display froze again but this time it was upside down and reversed like looking at it through a mirror. Unplugged the head unit again and back to normal. Another funny thing that happened was when the display lights turned off they came back on for a very second then off then on then off. When that happened the light in my sump fuge did the same and then came on. Came home this evening and the display was frozen again. It stopped at 8:25am. Reset the head unit and now the display is upside down and reversed like looking at it through a mirror.
Here is my current code. Maybe I have something wrong?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.StandardLights( Port1,22,30,13,30 ); //*sump fuge light
    ReefAngel.StandardLights( Port2,13,30,22,30 ); //*top fuge light
    ReefAngel.StandardLights( Port3,13,30,22,30 ); //*Actinic
    ReefAngel.StandardLights( Port4,13,30,22,30 ); //*Daylight
    ReefAngel.DosingPumpRepeat( Port5,0,720,60 ); //*kalk reactor
    ReefAngel.StandardATO( Port6,6000 ); //*Fresh water solenoid
    ReefAngel.StandardHeater( Port7,775,785 );
    ReefAngel.StandardLights( Port8,13,30,22,30 ); //*Light fan
    ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,30,5,60,30,5) );
    ReefAngel.PWM.SetActinic( PWMSlope(13,30,22,30,5,70,30,5) );
      byte x;
      byte y = 2;
      char text[7];
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Gonzo's Reef"); // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
      x = 12;
      y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
      ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
      ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
      y += MENU_START_ROW*2;
      x = 10;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, COLOR_BLACK, x, y, text); // Draw the temperature, white numbers on a colored background
      x += (16*4) + 8;
      ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
      ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
      ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
      ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
      // Code for drawing the relay box
  TempRelay &= ReefAngel.Relay.RelayMaskOff;
  TempRelay |= ReefAngel.Relay.RelayMaskOn;
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
Re: Display freeze
Elevatorguy1
Re: Display freeze
Thanks Roberto.
Looks like I do. The display has the tan tab.
Elevatorguy1
Re: Display freeze
Would the display cause the lights to flicker?
ufgators2k
Re: Display freeze
Post by ufgators2k »
I just had the same issue (display freeze, upside down). I also had a white screen a few days ago. Here is my code:
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
// Custom Menu setup
#include <avr/pgmspace.h>
prog_char menu2_label[] PROGMEM = "Refugium Light On/Off";
prog_char menu3_label[] PROGMEM = "Skimmer On/Off";
prog_char menu4_label[] PROGMEM = "ATO Clear";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Date / Time";
menu7_label
// Define Relay Ports by Name
// Port 1 - ATO
// Port 2 - Fuge Light
// Port 3 - Actinic Light
// Port 4 - Daylight
// Port 5 - Power Head
// Port 6 - Return Pump
// Port 7 - Heater
// Port 8 - Skimmer
#define Ato                1
#define Refugium           2
#define BlueLEDs           3
#define WhiteLEDs          4
#define PowerHead          5
#define ReturnPump         6
#define Heater             7
#define Skimmer            8
    //ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
    // Ports toggled in Water Change Mode - turn off ATO/Power Head/Return Pump
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    // Ports toggled when Lights On / Off menu entry selected - Actinic/Daylight
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.Relay.On( Port5 ); // Power head
    ReefAngel.Relay.On( Port6 ); // Return Pump
    ReefAngel.Relay.On( Port8 ); // Skimmer
    ReefAngel.PHMin=576;
    ReefAngel.PHMax=839;
    ReefAngel.StandardLights( Port2,20,30,10,0 );
    ReefAngel.StandardLights( Port3,10,30,20,30 );
    ReefAngel.StandardLights( Port4,11,0,19,45 );
    ReefAngel.StandardHeater( Port7,755,770 );
    //ReefAngel.PWM.SetDaylight( PWMParabola(11,0,20,0,10,100,10) );
    //ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,10,100,10) );
    // Use one float sensor (ATOLow) for the return section and one
    // for the ATO reservoir (ATOHigh)
    ReefAngel.SingleATO(true,Port1,45,0);
      ReefAngel.Relay.Off(Port1);
// Custom Main Menu
// Menu Code
void MenuEntry1() {
void MenuEntry2() {
  // Toggle refugium light between on/auto.
  ReefAngel.Relay.Override(Refugium, ReefAngel.Relay.Status(Refugium)+1);
void MenuEntry3() {
  // Toggle skimmer on/off.
  ReefAngel.Relay.Toggle(Skimmer);
void MenuEntry4() {
  ReefAngel.OverheatClear();
void MenuEntry5() {
  ReefAngel.ATOClear();
void MenuEntry6() {
  ReefAngel.SetupCalibratePH();
void MenuEntry7() {
  ReefAngel.SetupDateTime();
// Custom Main Screen
void DrawCustomMain() {
  const int NumScreens=2;
  static boolean drawGraph=true;
  // Main Header
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 28, 2,"Kopman's Reef");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
      break;
    case 1: { DrawStatus(5,40); break; }
  ReefAngel.LCD.DrawDate(4,122);
  // Draw Relays
  DrawRelays(12,94);
  if (ReefAngel.Joystick.IsLeft()) {
    ScreenID--; drawGraph=true;
  if (ReefAngel.Joystick.IsRight()) {
    ScreenID++; drawGraph=true;
void DrawCustomGraph() {
  if (ScreenID==0)
    ReefAngel.LCD.DrawGraph(5, 40);
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,30,y,"ATO Status");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y+10,"Resv",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y+10,"Sump",Font8x16);
  if (ReefAngel.HighATO.IsActive()) { // ATO reservoir is empty
    ReefAngel.LCD.FillCircle(55,y+15,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(55,y+15,5,COLOR_GREEN);
  if (ReefAngel.LowATO.IsActive()) { // Return pump water level is low
    ReefAngel.LCD.FillCircle(70,y+15,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,y+15,5,COLOR_GREEN);
  y+=25;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,15,y,"Heater Status");
  if (ReefAngel.Relay.Status(Heater) == 1) {
    ReefAngel.LCD.FillCircle(105,y+2,5,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(105,y+2,5,COLOR_RED);
  // Display Water level
  //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"AT0 Level:"); x+=65;
  //ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(),DPColor,x,y,1);
  //x+=5*(intlength(ReefAngel.WaterLevel.GetLevel())+1);
  //ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
  //y+=12; x=t;
void DrawRelays(int x, int y) {
  // Draw Relays
Re: Display freeze
Did you check which gen screen you have?
ufgators2k
Re: Display freeze
I haven't opened the device yet however I did just purchase it last month. I'll check it tonight.
ufgators2k
Re: Display freeze
It looks like it is a gen 3 screen
Re: Display freeze
Which libraries are you running?
ufgators2k
Re: Display freeze
1.0.7
ufgators2k
Re: Display freeze
As a note I don't have the ID line in my code but I believe you said 1.0.6 fixed that.
Re: Display freeze
I think we need to change that screen then. Please PM for RMA.
ufgators2k
Re: Display freeze
I PM'd you but I think it is stuck in my outbox.
Re: Display freeze
It'll be there till he reads it. No worries.
