New PH probe
Posted: Thu May 09, 2013 11:20 am
by kirkwood
When you purchase a new RA+ does the PH probe come calibrated?
Re: New PH probe
Posted: Thu May 09, 2013 11:23 am
It comes with default calibration, which is fairly close.
Re: New PH probe
Posted: Thu May 09, 2013 11:26 am
by kirkwood
maybe i have been reading old posts but it seemed like most recommended buying the 7 and 10 calibration fluid with any RA purchase.
New PH probe
Posted: Thu May 09, 2013 11:49 am
kirkwood wrote:maybe i have been reading old posts but it seemed like most recommended buying the 7 and 10 calibration fluid with any RA purchase.
yeah, those are the reference points for the probe. however there can be some conversion if you have different fluids.
Re: New PH probe
Posted: Thu May 09, 2013 1:23 pm
by kirkwood
rimai wrote:It comes with default calibration, which is fairly close.
so it will work correctly out of the box?
what is the optimal location of the probe to prevent bad readings? I don't plan on doing any diy housing and was just going to drop it in my sump... in my sump i run my skimmer pump, heaters, and 2 float switches from a JBJ ATO
Re: New PH probe
Posted: Thu May 09, 2013 1:30 pm
It will work and you will get fairly accurate reading, though for more accurate, the calibration with real standards is necessary.
