Help reduce size
Posted: Thu May 09, 2013 4:09 pm
by agentgreen
So it's been a while since I updated my RA, and I used the wizard to generate new code, and then modified it to be more like my old code. However, I'm oversized:
Binary sketch size: 32,406 bytes (of a 32,256 byte maximum)
Can someone help me trim this down 150 bytes haha.
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.DayLights( Port8 );
    ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Port8 ) );
    ReefAngel.StandardHeater( Box1_Port7 );
    ReefAngel.StandardHeater( Box1_Port8 );
    // Turn on Port 3 when the temp of T2 gets above 80.0 degrees
    if ( ReefAngel.Params.Temp[T2_PROBE] >= 800 ) ReefAngel.Relay.On(Port3);
    // Turn off Port 3 when the temp of T2 gets below 80.0 degrees
    if ( ReefAngel.Params.Temp[T2_PROBE] < 780 ) ReefAngel.Relay.Off(Port3);
    // Only turn on ATO and Koralia 8 for 20 minutes every hour.
    if (minute()<=20)
      ReefAngel.Relay.On(Box1_Port4);
    } else {
      ReefAngel.Relay.Off(Box1_Port4);
    ReefAngel.Portal( "agentgreen", "" );
    int x,y;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_DARKKHAKI,39,54, 100 );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
    // Date and Time
Re: Help reduce size
Posted: Thu May 09, 2013 6:49 pm
Do you have the ph expansion module?
Posted: Thu May 09, 2013 6:55 pm
by agentgreen
rimai wrote:Do you have the ph expansion module?
I do not.
Posted: Thu May 09, 2013 6:58 pm
you could get rid of those extra pingSerial() calls in the DrawCustomMain. you really only need one at the end of the function.
it may not make a huge difference but every little bit helps.
Posted: Thu May 09, 2013 7:02 pm
Remove this and it will fit:
    // pH Expansion
Posted: Thu May 09, 2013 7:04 pm
by agentgreen
rimai wrote:Remove this and it will fit:
    // pH Expansion
That worked, thanks! Must have mis-clicked in the wizard.
