Can't Upload any code.
Posted: Sun May 12, 2013 12:08 pm
I first tried uploading the sketch that the wizard created and this is the error I got...
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 31,500 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Steve\AppData\Local\Temp\build6010104045777780908.tmp\sketch_may09a.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
I have the USB to TTL Cable connected with the black lead to the right most pin on the connection.
The 2 left pins are open.
Then I tried to upload the WiFi Test Code and got this error...
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 30,138 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Steve\AppData\Local\Temp\build6010104045777780908.tmp\WifiTestCode.cpp.hex:i
avrdude: Recv:
Now I never see the head unit re-boot.
As a matter of fact there are no lights or anything on the head unit.
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
