Wifi Install help
Posted: Fri May 17, 2013 12:33 pm
by kirkwood
I went through the Wifi install without any problems. After the install it said that port forwarding had been completed.
My portal and droid app aren't recognizing the ip address that I'm entering.
What did I miss?
Wifi Install help
Posted: Fri May 17, 2013 1:24 pm
by dbmet
Did you check to make sure port 2000 is open ?
Wifi Install help
Posted: Fri May 17, 2013 3:24 pm
Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
Re: Wifi Install help
Posted: Fri May 17, 2013 6:12 pm
by kirkwood
lnevo wrote:Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
That's what I was using. What should I be using?
Posted: Fri May 17, 2013 6:17 pm
by dbmet
Use the one this site gives you..
http://whatismyipaddress.com/
