WIFI DHCP problem
Posted: Sat May 18, 2013 8:53 pm
I've been having some issues with my wifi dropping out lately and was checking some setting on my router. I wanted to be sure that nothing was interfering with the frequency my router was on so I switched it from auto (using channel 6) to a static channel. The RA wifi dropped immediately so I tried a few other channels with no success (including channel 6 that it was on when I started) then set it back to auto. Now my wifi module won't get a DHCP address at all. I was on the 4 firmware and reverted back to the previous version just to see if that was the issue but still no joy. I did a factory reset and re-ran the wifi setup and now I get the results below. It associates and authenticates fine, but fails to get a DHCP address. Any ideas? All other devices on my network connect and get addresses assigned just fine.
Opening Serial Port...
Connected to serial port COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 20 3 WiFly_GSX-2.36
< 22 12 3 wps_app
< 34 21 3 WiFly_GSX-2.45
< 55 1 10 config
< 56 1 3 wifly-GSX-400
< 57 1 3 NO NAME
< 58 1 3 wifly-GSX-400
< 69 1 10 user
< 76 13 3 wps_app
< 136 Free, Boot=34, Backup=58
< <2.45>
< load user
> load user
< AOK
< <2.45>
> save
< save
< Storing in config
< <2.45>
> save
< save
< Storing in config
< <2.45>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <2.45>
> set w s XXXX
< set w s XXXX
< AOK
< <2.45>
> set w p XXXX
< set w p XXXX
< AOK
< <2.45>
< AOK
< <2.45>
< set ftp address 198.175.253.161
< AOK
< <2.45>
> save
< save
< Storing in config
> reboot
< <2.45>
< reboot
< CMD
> show n
< show n
< SSid=2WIRE045
< Chan=3
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.45>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.45>
> reboot
< reboot
Removing connection to COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 12 3 wps_app
< 55 1 10 config
< 57 1 3 NO NAME
< 69 1 10 user
< 76 13 3 wps_app
< <2.45>
< load user
> load user
< AOK
< <2.45>
> save
< save
< Storing in config
< <2.45>
> save
< save
< Storing in config
< <2.45>
< AOK
< <2.45>
> set w s XXXX
< set w s XXXX
< AOK
< <2.45>
> set w p XXXX
< set w p XXXX
< AOK
< <2.45>
< AOK
< <2.45>
< AOK
< <2.45>
> save
< save
< Storing in config
> reboot
< <2.45>
< reboot
< CMD
> show n
< show n
< SSid=2WIRE045
< Chan=3
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.45>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.45>
> reboot
< reboot
