Help with custom screen
Posted: Mon May 20, 2013 1:59 pm
by ReeferBee
Hey guys I'm new here.
I found this code, posted by deckoz2302, of a really nice looking custom main screen.
//Custom Main, Graph & Menu
  Wire.requestFrom(8,8);
  for (int a=0;a<8;a++)
    if (Wire.available()) SeasonsVar[a]=Wire.receive();
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
  DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
  else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
  else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
  else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
  else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
  else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
  else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
  else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
  //  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
  ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
  ReefAngel.LCD.DrawText(0,255,75,109,"%");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
  ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
I'm looking to change some things about it. One big thing I need help with is changing the code to show what mode my wp40 is currently running.
Here is my current code running on my RA +
    ReefAngel.WaterChangePorts = Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,13,0,0,0 );
    ReefAngel.StandardLights( Port2,12,30,0,30 );
    ReefAngel.DosingPumpRepeat( Port3,0,120,60 );
    ReefAngel.DosingPumpRepeat( Port4,29,120,60 );
    ReefAngel.StandardHeater( Port6,780,792 );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
else if (hour()>=12 && hour()<16)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=16 && hour()<17)
  ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=17 && hour()<20)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 75% + - 20 on anti-sync mode
else if (hour()>=20 && hour()<24)
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
thanks so much!
Re: Help with custom screen
Posted: Mon May 20, 2013 3:20 pm
This should get you started:
byte vtechmode=0;
  vtechmode=6;
  vtechmode=2;
  vtechmode=5;
  vtechmode=2;
  vtechmode=6;
  vtechmode=4;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(0,255,18,12,"Jebao Mode:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,MoonPhaseLabel());
Posted: Mon May 20, 2013 4:34 pm
by ReeferBee
Thanks Roberto!
Posted: Mon May 20, 2013 8:44 pm
by ReeferBee
I'm having issues with using the DrawHugeText command for my sump temperature display. Part of the temp display is cut off. I've tried everything to fix it, no matter where I position it on the main screen its still cut off. If I need to post a pic of the screen I will.
byte vtechmode=0;
  vtechmode=6;
  vtechmode=2;
  vtechmode=5;
  vtechmode=2;
  vtechmode=6;
  vtechmode=4;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 3);
  ReefAngel.LCD.DrawText(0,255,18,16,"   WP40 Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,27,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,27,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,27,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,27,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,27,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,27,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,27,"Night");
  ReefAngel.LCD.DrawText(0,255,15,40,"Sump");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 25, 60, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 60, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
Posted: Mon May 20, 2013 8:53 pm
by ReeferBee
I figured it out!
Posted: Tue May 21, 2013 7:16 am
by cosmith71
What was it?
Posted: Tue May 21, 2013 8:12 am
by ReeferBee
Well, I thought I figured it out :)
I changed Num8x8 here:
To Num12x16
But now it's not showing the full temp reading. It says 9.69???
Any ideas?
Posted: Tue May 21, 2013 1:14 pm
by ReeferBee
I found my error once again. I changed the 10 after [T1_PROBE] to a 100, not knowing what the value was for. Now its back at 10 and everything looks great!
