Ato delay.
Posted: Tue May 21, 2013 6:21 pm
by johniii
Using a single low ato. How do I program a 30 second delay. My sump design creates a small wave and the switch clicks the relay rapidly. So if the switch stays open for 30 secs ato should run till the switch satisfys
Sent from my DROID RAZR using Tapatalk 2
Re: Ato delay.
Posted: Tue May 21, 2013 9:04 pm
Re: Ato delay.
Posted: Wed May 22, 2013 4:16 pm
by johniii
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.OverheatShutoffPorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.SingleATO( true,Port1,360,0 );
    ReefAngel.DosingPumpRepeat( Port2,0,240,10 );
    ReefAngel.DosingPumpRepeat( Port3,0,120,180 );
    ReefAngel.DosingPumpRepeat( Port5,60,120,180 );
    ReefAngel.StandardLights( Port6,14,0,22,0 );
    ReefAngel.StandardHeater( Port7,785,788 );
    ReefAngel.StandardHeater( Port8,785,789 );
    ReefAngel.PWM.SetDaylight( ReefCrestMode(35,15,true) );
    ReefAngel.PWM.SetActinic( ReefCrestMode(35,15,false) );
in the code above
ReefAngel.SingleATO(true,Port1,360,0) What does the 0 stand for.
I see that true is the switch state
port1 is the port
360 is the timeout
but what does the 0
nvm i looked at the thread and that 0 is interval ie pump can run every x hours
