Post or Get to URL
Posted: Mon May 27, 2013 5:22 pm
I am a web developer and would like to post alerts to an external URL to handle. As the ones included are limited.
Is there a away i can incorporate this with my current code?
//// Relay 1
#define CHILLER Port1 /// Hailea Chiller 1/2 HP
#define HEATER Port2 /// Backup heater
#define RETURN_PUMP Port3 /// Return Pump
#define CHILLER_PUMP Port4 /// Pump for chiller and UV
#define SKIMMER Port5 /// Protien Skimmer
#define REAR_PUMPS_1 Port6 /// Rear Pumps 1 & 2
#define REAR_PUMPS_2 Port7 /// Dosing Pump 1
#define DOSING_PUMP_1 Port8 /// Dosing Pump 1
//// Relay 2
#define FRONT_LIGHTS Box1_Port1 /// Front t5s (4 X 100W)
#define REAR_LIGHTS Box1_Port2 /// Rear t5s (4 X 100W)
#define MIDDLE_LIGHTS Box1_Port3 /// Rear t5s (2 X 100)
#define MOON_LIGHTS Box1_Port4 /// Moon Lights (LED)
#define SUMP_LIGHTS Box1_Port5 /// Sump Lights (LED)
#define SALINITY_POWER Box1_Port7 /// Power to Salinity Module
#define ORP_POWER Box1_Port8 /// Power to ORP Module
#define TANK_TEMPRATURE ReefAngel.Params.Temp[T1_PROBE] /// tank temprature
/// outlet styles & colors
#define OutletBorderColor COLOR_ROYALBLUE /// Relay Border
#define OutletOnBGColor COLOR_WHITE /// Relay On
#define OutletOnFGColor COLOR_ROYALBLUE /// Relay Text Color
#define OutletOffBGColor COLOR_ROYALBLUE /// Relay Off0x4F
#define OutletOffFGColor COLOR_WHITE /// Relay Text Color 0xFF
#define YES 1 //// YES
#define NO 0 //// NO
/// error count & logs
int errorCount = 0;
int lowATO = NO;
int highATO = NO;
int highATOAlert = NO;
int powerFailure = NO;
int powerFailureCount = 0;
int powerFailureCountStarted = NO;
int noPowerAlert = NO;
int lowROWater = NO;
int highTemp = NO;
int lowTemp = NO;
int lowTempAlert = NO;
int highTempAlert = NO;
int phOut = NO;
int phAlert = NO;
byte lastMinute = 0;
void setup(){
ReefAngel.Init(); /// Initialize controller
ReefAngel.SetTemperatureUnit( Celsius ); /// set Temp to Celcius
/// Toggled Ports
ReefAngel.LightsOnPorts = FRONT_LIGHTS | REAR_LIGHTS;
ReefAngel.FeedingModePorts = RETURN_PUMP | REAR_PUMPS_1 | REAR_PUMPS_2 | CHILLER | CHILLER_PUMP | SKIMMER;
ReefAngel.WaterChangePorts = RETURN_PUMP | REAR_PUMPS_1 | REAR_PUMPS_2 | CHILLER | CHILLER_PUMP | SKIMMER | FRONT_LIGHTS;
ReefAngel.OverheatShutoffPorts = HEATER | FRONT_LIGHTS | REAR_LIGHTS | MIDDLE_LIGHTS;
/// Immediate Start ( delayed starts in loop )
ReefAngel.Relay.On(REAR_PUMPS_1);
ReefAngel.Relay.On(REAR_PUMPS_2);
if(powerFailure == NO){
ReefAngel.Relay.On(SUMP_LIGHTS);
ReefAngel.Relay.On(SALINITY_POWER);
ReefAngel.Relay.On(ORP_POWER);
void DrawCustomMain(){
char text[7];
byte x = 6;
byte y = 2;
byte t;
//ReefAngel.LCD.DrawDate(COLOR_WHITE,COLOR_BLACK,6, 2);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_ROYALBLUE,0,1," RED SEA MAX S 650 ");
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,COLOR_WHITE,4,13,"Tank: Sump:");
ReefAngel.LCD.DrawText(COLOR_MIDNIGHTBLUE, COLOR_WHITE, 35, 13, text);
if(ReefAngel.Params.Temp[T1_PROBE]>=260 || ReefAngel.Params.Temp[T2_PROBE]>=260)
highTemp = YES;
highTemp = NO;
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(COLOR_MIDNIGHTBLUE, COLOR_WHITE, 101, 13, text);
//ReefAngel.LCD.Clear(DefaultFGColor, 0, 23, 128, 23);
if(highTemp==NO && (ReefAngel.Params.Temp[T1_PROBE] <230 || ReefAngel.Params.Temp[T2_PROBE]<230))
ReefAngel.Relay.On(HEATER);
if(ReefAngel.Params.Temp[T1_PROBE] <210 || ReefAngel.Params.Temp[T2_PROBE]<210)
lowTemp = YES;
lowTemp = NO;
/// top relay styles - bring to edge
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 25, 25, 25);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 26, 12, 36);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 37, 25, 37);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 114, 25, 130, 25);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 117, 26, 130, 36);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 114, 37, 130, 37);
/// relay 1 - 8
ReefAngel.LCD.DrawOutletBox(12, 25, TempRelay);
/// bottom relay styles - bring to edge
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 38, 12, 48);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 49, 12, 49);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 117, 38, 130, 48);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 114, 49, 130, 49);
/// relay 9 - 16
ReefAngel.LCD.DrawOutletBox(12, 37, TempRelay);
/// set high low
//ReefAngel.LCD.Clear(COLOR_GREEN, 0, 60, 25, 85);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE,COLOR_WHITE,20,64,"LOW", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE,COLOR_WHITE,85,64,"HIGH", Font8x16);
/// seperator before water level & pH
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 76, 130, 77);
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,COLOR_WHITE,10,80,"pH:");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 31, 80, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,COLOR_WHITE,70,80,"ATO:");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel() , 1);
strcat(text,"% ");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,95,80, text);
ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 90, 130, 91);
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,COLOR_WHITE,6,96,"Sal:");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,31,96, text);
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,COLOR_WHITE,70,96,"ORP:");
ConvertNumToString(text, ReefAngel.Params.ORP, 1);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,95,96, text);
//ReefAngel.LCD.Clear(COLOR_ROYALBLUE, 0, 107, 128, 122);
if(hour()>=18 && hour()<22){
ReefAngel.LCD.Clear(COLOR_DEEPSKYBLUE,0, 107, 130, 121);
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_DEEPSKYBLUE,0,110, " Moon Mode ");
else if(hour()>=23 || (hour()>=0 && hour()<8)){
ReefAngel.LCD.Clear(COLOR_BLACK,0, 107, 130, 121);
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_BLACK,0,110, " Night Mode ");
else if(hour()>=8 && hour()<18){
ReefAngel.LCD.Clear(COLOR_YELLOW,0, 107, 130, 121);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_YELLOW,0,110, " Day Mode ");
void DrawCustomGraph(){
void loop(){
if (ReefAngel.Joystick.IsButtonPressed())
WifiSendAlert(1);
/// lighting if no errors
// remove ReefAngel.DosingPumpRepeat(DOSING_PUMP_1,0,1,15);
ReefAngel.StandardLights(MIDDLE_LIGHTS,8,30,19,30);
ReefAngel.StandardLights(REAR_LIGHTS,9,00,19,30);
ReefAngel.StandardLights(FRONT_LIGHTS,10,00,18,30);
ReefAngel.StandardLights(MOON_LIGHTS,19,00,23,00);
/* remove if(highATO + lowATO + powerFailure <1){ */
/// Default LEDS to 0 - useed for error reporting and system status
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
/// Delayed Starts
/// 1 Minute
ReefAngel.Relay.DelayedOn (SKIMMER,1);
ReefAngel.Relay.DelayedOn (RETURN_PUMP,1);
/// 2 Minute
ReefAngel.Relay.DelayedOn(CHILLER,2);
ReefAngel.Relay.DelayedOn(CHILLER_PUMP,2);
// remove }
/// Check for errors
/// Check Sump Levels
/* remove if (!ReefAngel.LowATO.IsActive() || !ReefAngel.HighATO.IsActive()){
if(!ReefAngel.LowATO.IsActive()){
lowATO = YES;
ReefAngel.LCD.FillCircle(72,67,6,COLOR_RED);
else{
lowATO = NO;
ReefAngel.LCD.FillCircle(72,67,6,COLOR_GREEN);
if(!ReefAngel.HighATO.IsActive()){
highATO = YES;
ReefAngel.LCD.FillCircle(55,67,6,COLOR_RED);
else{
highATO = NO;
ReefAngel.LCD.FillCircle(55,67,6,COLOR_GREEN);
else{
remove */
lowATO = NO;
highATO = NO;
//remove }
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)){
powerFailure = YES;
else{
powerFailure = NO;
if(ReefAngel.WaterLevel.GetLevel()<20)
lowROWater = YES;
lowROWater = NO;
checkForErrors();
//// End Code
ReefAngel.Portal( "" ,"");
void checkForErrors(){
errorCount = 0;
/// see if any errors have been logged
/// first check sump levels
if(lowATO+highATO>0){
if(lowATO==YES){
//char text2[7];
//ConvertNumToString(text2, lastMinute,1);
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," LOW SUMP LEVEL ", Font8x16);//
errorCount++;
//ReefAngel.PWM.SetDaylight(ErrorPulse(0, 100, 120, false));
//checkLastMin(lastMinute, 1);
if(highATO==YES){
errorCount++;
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," HIGH SUMP LEVEL ", Font8x16);
ReefAngel.PWM.SetDaylight(ErrorPulse(0, 60, 5, false));
ReefAngel.PWM.SetActinic(ErrorPulse(0, 100, 5, false));
else if(lowROWater == YES){
errorCount++;
ReefAngel.PWM.SetActinic(100);
/// check tempreature levels
if(highTemp==YES){
errorCount++;
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," HIGH TEMPRATURE ", Font8x16);
ReefAngel.Relay.Off(FRONT_LIGHTS);
ReefAngel.Relay.Off(REAR_LIGHTS);
ReefAngel.Relay.Off(MIDDLE_LIGHTS);
if(highTempAlert==NO){
WifiSendAlert(2);
highTempAlert = YES;
if(lowTemp==YES){
errorCount++;
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," LOW TEMPRATURE ", Font8x16);
ReefAngel.Relay.Off(CHILLER);
ReefAngel.Relay.On(FRONT_LIGHTS);
ReefAngel.Relay.On(REAR_LIGHTS);
ReefAngel.Relay.On(MIDDLE_LIGHTS);
if(lowTempAlert==NO)
WifiSendAlert(3);
lowTempAlert = YES;
if(lowTemp==NO && highTemp==NO){
lowTempAlert = NO;
highTempAlert = NO;
if(ReefAngel.Params.PH > 830 || ReefAngel.Params.PH < 795){
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," CHECK pH ", Font8x16);
if(phAlert==NO){
if(ReefAngel.Params.PH > 830)
WifiSendAlert(5);
WifiSendAlert(6);
phAlert = YES;
errorCount++;
phAlert = NO;
/// check for power failure
if(powerFailure==YES){
errorCount++;
if(powerFailureCountStarted==NO){
powerFailureCountStarted = YES;
powerFailureCount = powerFailureCount + 1;
/// if no power what to do
/// immediately kill
ReefAngel.Relay.Off(SUMP_LIGHTS);
ReefAngel.Relay.Off(SALINITY_POWER);
ReefAngel.Relay.Off(ORP_POWER);
if(powerFailureCount > 1800){
ReefAngel.Relay.Off (SKIMMER); /// kill skimmer after 3 minutes
ReefAngel.Relay.Off (SUMP_LIGHTS); /// kill sump lights after 3 minutes
if(powerFailureCount > 3000) {
if(TANK_TEMPRATURE <26.6){
ReefAngel.Relay.Off (CHILLER); /// kill chiller after 5 minutes
ReefAngel.Relay.Off (CHILLER_PUMP); /// kill chiller pump after 5 minutes
ReefAngel.Relay.Off (RETURN_PUMP); /// kill return pump after 5 minutes
else{
ReefAngel.Relay.On (CHILLER); /// kill chiller after 5 minutes
ReefAngel.Relay.On (CHILLER_PUMP); /// kill chiller pump after 5 minutes
ReefAngel.Relay.On (RETURN_PUMP); /// kill return pump after 5 minutes
ReefAngel.Relay.Off(REAR_PUMPS_2); /// kill rear pumps
/*f(powerFailureCount > 3000 && TANK_TEMPRATURE >26.6){ //// if ten minutes pass or water gets too warm.
ReefAngel.Relay.On (CHILLER); /// turn back on
ReefAngel.Relay.On (CHILLER_PUMP); /// turn back on
ReefAngel.PWM.SetDaylight(ErrorPulse(10, 60, 1, false));
ReefAngel.PWM.SetActinic(ErrorPulse(0, 100, 1, false));
/// No power countdown
char text[40] = " NO POWER: ";
char text2[7];
ConvertNumToString(text2, powerFailureCount,10);
strcat(text, text2);
strcat(text, " ");
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50,text, Font8x16);
//ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_RED,0,50," POWER OUTAFGE ", Font8x16);
else if(errorCount==0){
ReefAngel.LCD.DrawLargeText(COLOR_WHITE,COLOR_GREEN,0,50," STATUS OK ", Font8x16);
byte ErrorPulse(byte MinPulse, byte MaxPulse, int PulseDuration, boolean PulseSync)
byte tspeed=0;
MinPulse=constrain(MinPulse,0,100);
MaxPulse=constrain(MaxPulse,0,100);
tspeed=(now()%(PulseDuration*2)<PulseDuration?MinPulse:MaxPulse);
if (PulseSync)
return tspeed;
return (tspeed==MinPulse)?MaxPulse:MinPulse;
byte checkLastMin(byte lastMinute, byte minutesToWait){
if(lastMinute == 0)
lastMinute = minute() ;
if(minute()-lastMinute == minutesToWait){
ReefAngel.PWM.SetDaylight(ErrorPulse(0, 60, 2, false));
if(lastMinute != minute())
void WifiSendAlert(byte id)
Serial.print("GET /status/alert.asp?e=emailAdd&id=");
Serial.print(id,DEC);
Serial.println("\n\n");
//// Relay 1
//// Relay 2
int errorCount = 0;
int lowATO = NO;
int highATO = NO;
int highTemp = NO;
int lowTemp = NO;
int phOut = NO;
int phAlert = NO;
void setup(){
/// Toggled Ports
char text[7];
byte x = 6;
byte y = 2;
byte t;
highTemp = YES;
highTemp = NO;
lowTemp = YES;
lowTemp = NO;
/// relay 1 - 8
/// relay 9 - 16
/// set high low
strcat(text,"% ");
void loop(){
WifiSendAlert(1);
/// Delayed Starts
/// 1 Minute
/// 2 Minute
// remove }
lowATO = YES;
else{
lowATO = NO;
highATO = YES;
else{
highATO = NO;
else{
remove */
lowATO = NO;
highATO = NO;
//remove }
powerFailure = YES;
else{
powerFailure = NO;
lowROWater = YES;
lowROWater = NO;
checkForErrors();
//// End Code
errorCount = 0;
if(lowATO==YES){
//char text2[7];
errorCount++;
if(highATO==YES){
errorCount++;
errorCount++;
if(highTemp==YES){
errorCount++;
WifiSendAlert(2);
if(lowTemp==YES){
errorCount++;
WifiSendAlert(3);
lowTempAlert = YES;
lowTempAlert = NO;
highTempAlert = NO;
if(phAlert==NO){
WifiSendAlert(5);
WifiSendAlert(6);
phAlert = YES;
errorCount++;
phAlert = NO;
errorCount++;
else{
char text2[7];
strcat(text, " ");
byte tspeed=0;
if (PulseSync)
return tspeed;
if(lastMinute == 0)
