Custom code for cloud
Posted: Thu May 30, 2013 11:53 am
by jjdezek
Looking for a code to make a cloud pass over tank. Left white LEDs port 0 blues port 1 middle whites port2 blues port3 right white LEDs port4 blues port5
Re: Custom code for cloud
Posted: Thu May 30, 2013 11:54 am
How do you envision this working for you?
Going left to right?
Does it go all off before it comes back on? Or left starts to ramp up again before right goes dark?
Posted: Thu May 30, 2013 1:17 pm
by jjdezek
Either left or right doesn't make a difference to me. I was thinking say left one ramps down to 15 at a fast pace then once its close to low end the middle starts to go down to same 15 same speed and repeat for right LEDs let stay dim for a min. Or 2 then left ramps back up and goes across like it did for dimming. Another thing I'm not sure if it matters but I run my blues at 40 and whites at 35 peak power.
Posted: Fri May 31, 2013 9:59 am
Try this:
#define slope_duration    9 // duration of slope in seconds
#define cloud_duration    120 // duration of cloud in seconds
#define cloud_percentage  15  // percentage for the dimming channel when the cloud is passing
unsigned long dim_millis;
boolean start_cloud=false;
int ChannelValues[]={
  0,0,0,0,0,0};
  ReefAngel.Init();
  for (int i=0;i<6;i++)
    ChannelValues[i]=60; // Just for initial values
  if (now()%300==0) start_cloud=true;
  if (start_cloud) // Cloud trigger was fired. Starting cloud
    dim_millis=millis();
    start_cloud=false;
  // Cloud started
  // Ramping down
  if (millis()-dim_millis<slope_duration*1000)
    byte OriginalChannelValues[]={
      0,0,0,0,0,0    };
      OriginalChannelValues[i]=ChannelValues[i];
    ChannelValues[0]=map(millis()-dim_millis,0,slope_duration/3*1000,OriginalChannelValues[0],cloud_percentage);
    ChannelValues[1]=map(millis()-dim_millis,0,slope_duration/3*1000,OriginalChannelValues[1],cloud_percentage);
    ChannelValues[2]=map(millis()-dim_millis,slope_duration/3*1000,slope_duration*2/3*1000,OriginalChannelValues[2],cloud_percentage);
    ChannelValues[3]=map(millis()-dim_millis,slope_duration/3*1000,slope_duration*2/3*1000,OriginalChannelValues[3],cloud_percentage);
    ChannelValues[4]=map(millis()-dim_millis,slope_duration*2/3*1000,slope_duration*1000,OriginalChannelValues[4],cloud_percentage);
    ChannelValues[5]=map(millis()-dim_millis,slope_duration*2/3*1000,slope_duration*1000,OriginalChannelValues[5],cloud_percentage);
      if (ChannelValues[i]<0) ChannelValues[i]=0;
      ChannelValues[i]=constrain(ChannelValues[i], cloud_percentage, OriginalChannelValues[i]);
  // Full Cloud
  // Stay at defined cloud_percentage
  if (millis()-dim_millis>slope_duration*1000 && millis()-dim_millis<(slope_duration+cloud_duration)*1000 )
      ChannelValues[i]=cloud_percentage;
  // Cloud is ending
  // Ramping up
  if (millis()-dim_millis>(slope_duration+cloud_duration)*1000 && millis()-dim_millis<(slope_duration+slope_duration+cloud_duration)*1000 )
      0,0,0,0,0,0    };
    ChannelValues[0]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),0,slope_duration/3*1000,cloud_percentage,OriginalChannelValues[0]);
    ChannelValues[1]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),0,slope_duration/3*1000,cloud_percentage,OriginalChannelValues[1]);
    ChannelValues[2]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),slope_duration/3*1000,slope_duration*2/3*1000,cloud_percentage,OriginalChannelValues[2]);
    ChannelValues[3]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),slope_duration/3*1000,slope_duration*2/3*1000,cloud_percentage,OriginalChannelValues[3]);
    ChannelValues[4]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),slope_duration*2/3*1000,slope_duration*1000,cloud_percentage,OriginalChannelValues[4]);
    ChannelValues[5]=map(millis()-dim_millis-((slope_duration+cloud_duration)*1000),slope_duration*2/3*1000,slope_duration*1000,cloud_percentage,OriginalChannelValues[5]);
    ReefAngel.PWM.SetChannel(i,ChannelValues[i]);
byte x,y;
  ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
  ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
  ReefAngel.LCD.DrawDate(6, 122);
  ReefAngel.LCD.DrawMonitor(15, 20, ReefAngel.Params,
  ReefAngel.LCD.Clear(DefaultFGColor,5,52,127,52);
  ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,30,55,"PWM Expansion");
  x=15;
  y=68;
  for (int a=0;a<6;a++)
    if (a>2) x=75;
    if (a==3) y=68;
    ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :");
    ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a);
    ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
    strcat(text,"  ");
    ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,text);
    y+=10;
  ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
This test code will create a cloud every 5 minutes, that lasts for about 2 minutes.
Posted: Fri May 31, 2013 11:14 am
by jjdezek
do i copy and paste that between the custom code area?
Posted: Fri May 31, 2013 11:21 am
No.
It's the entire code already as it is.
Just for you to test.
Posted: Fri May 31, 2013 11:24 am
by jjdezek
Ok so load that only?
Posted: Fri May 31, 2013 11:34 am
by jjdezek
Got it loaded. Right away it dimmed down to 15 from left to right pretty quickly. Stayed dim thin it all turned on really bright like 60% then I think it dimmed right back down to 15 so its almost like its backwards other then how it jumped all lights up to 60. Blues should be 35% whites 40%
Posted: Sat Jun 01, 2013 2:39 pm
by jjdezek
Is there some way to fix that coding?
Posted: Sat Jun 01, 2013 2:51 pm
Have you tested?? Does it work?
The 60% was hard coded as just the example.
It's this part of the code:
I left a few comments through the code for you to kind of follow what the code is doing.
If it works, you can merge into your own code.
Posted: Sat Jun 01, 2013 3:19 pm
by jjdezek
It dimmed down fine but it didn't ramp back up it just flashed instantly back up. Also can I slow it down some so it don't move in quit so fast?
Posted: Sat Jun 01, 2013 4:16 pm
Yeah, just change the duration of the ramp.
Posted: Sat Jun 01, 2013 4:37 pm
by jjdezek
ok cool how about the ramping back up part? it doesnt ramp up it just goes from 15 to 60 i looked through the code but not real sure what im looking at, where is the ramp up rate? also when it does work correctly what part of this code do i use or do i use the entire code?
Posted: Sun Jun 02, 2013 6:20 am
by jjdezek
rimai wrote:Have you tested?? Does it work?
can you set two different values? channels 0,2,4 at 40 and channels 1,3,5 at 35?
Posted: Sun Jun 02, 2013 7:50 am
I still didn't have time to test the ramp up.
What are you using for your code to set those %s right now?
Posted: Sun Jun 02, 2013 8:39 am
by jjdezek
i did everything through the wizard
Posted: Tue Jun 04, 2013 3:58 pm
by jjdezek
dont need this code anymore since i loaded the weather lighting code into the dimmer expansion module. thanks for the help.
