ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardFan( Port1,771,781 );
ReefAngel.StandardHeater( Port2,751,761 );
ReefAngel.DosingPumpRepeat( Port5,0,240,120 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.StandardLights( Port7,9,0,19,0 );
ReefAngel.StandardLights( Port8,9,0,19,0 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,360,120 );
ReefAngel.DosingPumpRepeat( Box1_Port2,60,360,120 );
ReefAngel.SingleATO( true,Box1_Port3,60,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,0,100,60,15) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,0,100,60,15) );
The first part:
Next part:
Another way to comment is like this:
/* These symbols
Make Comments
Out of Everything
Between Them.
void means that when we call this function, we don't expect it to tell us anything back. It's a little out of place here since we never really call setup, it is automatically run once when the program starts up. The empty () means we aren't sending any data to it. Again, kind of extra in this case.
Next, we have {. This starts a section of code. In this case, it's the beginning of setup(). Every function will have a { at the beginning and a } at the end. In addition, you may have other sets of these inside the function. An "if" statement is a good example of this. Again, they just define a section of the code.
Please note that everything is CaSe SeNsItIvE! T1_PROBE is not the same as t1_probe. Capitalization is important.
A note on function names. You can name functions just about anything you like. Writers will use "." and "_" as part of the function name. The "." is used to denote different functions in a group. Like ReefAngel.TempProbe and ReefAngel.OverheatProbe, both parts of the ReefAngel group. The "_" is used intstead of spaces, which are not allowed.
Finally,
Part 2 to follow.
