Controller freezing and trouble compiling sketch
Posted: Wed Jun 12, 2013 8:04 pm
About 2 days ago my controller unit froze up, screen blank, red status light blinking and no response to input from the joystick. It resets properly when power cycled and returns to normal function. It's happened a couple more times in the past few days.
I have the RA Plus unit and it's been running without issue for quite awhile. No recent changes were made to the hardware or code.
My computer was upgraded recently though and I copied the Reef Angel folder over to the drive. I wanted to try uploading my code again to see if that helped but now I get a wall of - 'xxxxx' was not declared in this scope messages. The first being 'ReefAngel' was not declared in this scope.
Hoping you can help. It's been smooth sailing for quite awhile now. The Arduino software is v1.01 and I have the Board option set to Reef Angel Plus Controller.
Edit: the Wi-Fi unit lost connection also. I unplugged it for now. Feed mode works okay but water change does not for some reason.
Here's my code:
Here's my code:
// Autogenerated file by RAGen (v1.2.2.171), (07/19/2012 20:00)
// RA_071912_2000.ino
#define DisplayImages
#define DateTimeSetup
#define DosingPumpSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define InstalledRelayExpansionModules 1
#define WDT
#define PWMEXPANSION
#define IOEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
#include <avr/wdt.h>
// Globals Needed for Params on Custom Main
byte x,y;
int v;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, "Sean's 58G Money Pit");
// Display T2 Header Text
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,8,14,"Tank");
// Display the T2 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 4, 24, text, Num8x16);
// Display the T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
// Display the T1 Temp Value
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP10wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
// Display PMW Expansion Channel Headers and % Values
ReefAngel.LCD.Clear(DefaultFGColor,5,65,127,65);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,31,68,"LED Dimming");
x=15;
y=78;
for (int a=0;a<4;a++)
if (a>1) x=75;
if (a==2) y=78;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a);
ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,text);
y+=10;
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
// Display Expansion Relay Box 1
ReefAngel.LCD.DrawOutletBox(13,109, TempRelay);
//Draw Date & Time
ReefAngel.LCD.DrawDate(6, 123);
void DrawCustomGraph() // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
//Ports that are always on
ReefAngel.Relay.On(Box0_Port4);
ReefAngel.Relay.On(Box0_Port5);
ReefAngel.Relay.On(Box1_Port4);
ReefAngel.Relay.On(Box1_Port5);
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
// define T2 probe as temp probe
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit ;
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
ReefAngel.StandardLights(Box0_Port1,11,0,22,0);
ReefAngel.StandardLights(Box0_Port2,23,0,10,0);
ReefAngel.StandardLights(Box0_Port3,10,0,23,0);
ReefAngel.StandardLights(Box1_Port8,10,0,23,30);
ReefAngel.StandardFan(Box0_Port6, 773,777);
ReefAngel.StandardFan(Box0_Port7, 775,790);
ReefAngel.StandardHeater(Box0_Port8,768,771);
ReefAngel.DosingPumpRepeat(Box1_Port3,0,360,600);
ReefAngel.DosingPumpRepeat(Box1_Port1,0,60,90);
ReefAngel.Relay.DelayedOn(Box0_Port4,30 );
ReefAngel.Relay.DelayedOn(Box1_Port4,30 );
ReefAngel.PWM.SetChannel(0,PWMSlope(11,0,22,0,12,30,60,10));
ReefAngel.PWM.SetChannel(1,PWMSlope(10,0,23,0,12,45,60,10));
ReefAngel.PWM.SetChannel(2,PWMSlope(10,0,23,0,12,45,60,10));
ReefAngel.PWM.SetChannel(3,PWMSlope(10,0,23,0,12,45,60,10));
ReefAngel.Portal("reefer gladness", "xxxxxxxx");
//------------------------------------------------- End PWM Expansion Code for Slope ----------------------------------------------
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<10) // Defining "Nightmode" hours for VorTech = between 11 PM and 10 AM
ReefAngel.RF.UseMemory=false;
vtechmode = 9;
if (vtechmode==9) ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
