Flow question
Posted: Thu Jun 20, 2013 1:30 pm
by Smotz
I have a routine in my code that says "if in custom mode then set my dc pump to do reefcrest , x y ,z"
As the code runs and cycles through itself over and over, does it re-read that "if" line and re-apply the statement?
So if reefmode is supposed to run at a set speed for 5 seconds, if the code re-applies because it completed and restarted, does it interrupt that ?
Re: Flow question
Posted: Thu Jun 20, 2013 1:33 pm
No it won't the variables within the reefcrestmode are "static" meaning it doesnt reset each times its run.
And if you didn't do that in your custom mode code, the default code does exactly that..runs that same function each iteration of loop()
Re: Flow question
Posted: Thu Jun 20, 2013 1:39 pm
by Smotz
lnevo wrote:No it won't the variables within the reefcrestmode are "static" meaning it doesnt reset each times its run.
By static do you mean that if the program determines that the value is the same it does not change it or re-apply it?
Did I do that correctly?
////  Port 1			Heater
////  Port 2			ATO pump
////  Port 3			Reactor Pump
////  Port 4			Protien Skimmer
////  Port 5			Return Pump
////  Port 6			Wavemaker
////  Port 7                    UV Sterilizer
////  Port 8                    Fuge Light
////  Always on - Lights & Salinity Module
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define FugelightBit   1<<7
#define UVlightBit   1<<6
#define WaveBit   1<<5
#define ReturnBit   1<<4
#define SkimmerBit   1<<3
#define ReactorBit   1<<2
#define TopoffBit   1<<1
#define HeaterBit   1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
  ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
  ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  ReefAngel.LightsOnPorts = FugelightBit;
  ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  // Use T1 (SUMP) probe as temperature and overheat functions
  ReefAngel.Relay.On( Return );
  ReefAngel.Relay.On( Reactor );
  ReefAngel.Relay.On( Wave );
  ReefAngel.StandardHeater( Heater );
  ReefAngel.StandardATO( Topoff );
  ReefAngel.MoonLights( Fugelight );
  ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
  ReefAngel.Relay.DelayedOn(Skimmer,2);
  ReefAngel.Relay.DelayedOn(UVlight,1);
  ReefAngel.DCPump.FeedingSpeed=30;
// Custom Wave Routine
  if (ReefAngel.DCPump.Mode==Custom)    {
    ReefAngel.DCPump.SetMode( ReefCrest,wpWavStr,wpWavOff );
    // Set Wave Str
  if (wpMode=1) wpWavStr=45;
  if (wpMode=2) wpWavStr=50;
  if (wpMode=3) wpWavStr=55;
  //Set the Wave OffSet
  wpWavOff=15;
  // set the wpMode
  if ( (hour() >= 5) && (hour() < 8) ) wpMode=1;       // from 5am - 8am
  if ( (hour() >= 8) && (hour() < 11) ) wpMode=2;      // from 8am - 11am
  if ( (hour() >= 11) && (hour() < 14) ) wpMode=3;     // from 11a - 2pm
  if ( (hour() >= 14) && (hour() < 17) ) wpMode=2;     // from 2pm - 5pm
  if ( (hour() >= 17) && (hour() < 20) ) wpMode=1;     // from 5pm - 8pm
  if ( (hour() >= 20) && (hour() < 23) ) wpMode=2;     // from 8pm - 11p
  if ( (hour() >= 23) && (hour() < 2) ) wpMode=3;      // from 11pm - 2am
  if ( (hour() >= 2) && (hour() < 5) ) wpMode=2;       // from 2am - 5am
// end Custom Wave Routine
  //  Only turn on UV Sterilizer between 11pm and 5am
  if ( (hour() >= 5) && (hour() < 23) )  // from 5a - 11p
  ReefAngel.Relay.Off(UVlight);
  else ReefAngel.Relay.On(UVlight);
  ReefAngel.Portal( "Smotz" );
  int x,y;
  char buf[16];
if (ReefAngel.DCPump.Mode==Custom) sprintf(buf,"RC %d% +/-%d%",wpWavStr,wpWavOff);
else sprintf(buf,"%d%",ReefAngel.DCPump.Mode);
  x = 15;
  y = 52;
  //ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
  //ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
  ReefAngel.LCD.DrawText(0,255,x,y,buf);
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Re: Flow question
Posted: Thu Jun 20, 2013 2:07 pm
No, you don't need to make your variables static because they are global variables.
The point was inside the ReefCrestMode function, the variables that track the time and when to change, etc are static and so they are not re-initialized each time ReefCrestMode is called.
You can leave your global variables (wpMode, etc..) the way you called them originally.
The only thing I would do different with your code is put the SetMode command after all your wpWavStr and wpWavOff are determined. It will still work, but whatever you choose in the logic after it currently will not be applied till the next iteration of loop...
