V1.0.9 custom dc pump setting
Posted: Sat Jun 22, 2013 9:57 am
by jjdezek
Under the list of DC pump settings is a custom setting. What is this for, can you make a custom code to load in that space?
Re: V1.0.9 custom dc pump setting
Posted: Sat Jun 22, 2013 10:25 am
Yeah it's a hook so you can define your own mode. Whether it would be a time based sync or a custom function, it will let you write whatever you want and choose it from the portal or go back to another mode later.
Posted: Sat Jun 22, 2013 10:31 am
by jjdezek
Ok if you write a custome code where would you place it to access it under the costom option?
Posted: Sat Jun 22, 2013 10:36 am
In the area where it says insert custom code here
http://forum.reefangel.com/viewtopic.php?p=28394#p28394
Posted: Sat Jun 22, 2013 11:10 am
by jjdezek
ok got it thanks
