// Autogenerated file by RAGen (v1.0.4.92), (09/09/2011 07:48)
// RA_090911_0748.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#define RelayExp
Box 0 Port 1 = MH1
Box 0 Port 2 = MH2
Box 0 Port 3 = Canopy Fans
Box 0 Port 4 = Powerhead 1
Box 0 Port 5 = Powerhead 2
Box 0 Port 6 = Heater 1
Box 0 Port 7 = EMPTY
Box 0 Port 8 = EMPTY
Box 1 Port 1 = Return Pump
Box 1 Port 2 = Skimmedr
Box 1 Port 3 = Refugium Light
Box 1 Port 4 = ATO
Box 1 Port 5 = EMPTY
Box 1 Port 6 = EMPTY
Box 1 Port 7 = EMPTY
Box 1 Port 8 = EMPTY
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "agentgreen";
prog_char probe1_label[] PROGMEM = "Sump";
prog_char probe2_label[] PROGMEM = "Canopy";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "MH1";
prog_char relay2_label[] PROGMEM = "MH2";
prog_char relay3_label[] PROGMEM = "FANS";
prog_char relay4_label[] PROGMEM = "PH1";
prog_char relay5_label[] PROGMEM = "PH2";
prog_char relay6_label[] PROGMEM = "H1";
prog_char relay7_label[] PROGMEM = "H2";
prog_char relay8_label[] PROGMEM = "NA";
prog_char relay11_label[] PROGMEM = "Return";
prog_char relay12_label[] PROGMEM = "Skimmer";
prog_char relay13_label[] PROGMEM = "RefugLight";
prog_char relay14_label[] PROGMEM = "ATO";
prog_char relay15_label[] PROGMEM = "NA";
prog_char relay16_label[] PROGMEM = "NA";
prog_char relay17_label[] PROGMEM = "NA";
prog_char relay18_label[] PROGMEM = "NA";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label,
relay11_label, relay12_label, relay13_label, relay14_label, relay15_label, relay16_label,
relay17_label, relay18_label};
void WifiSendAlert(byte id, boolean IsAlert)
static byte alert_status;
if (IsAlert)
if ((alert_status & 1<<(id-1))==0)
alert_status|=1<<(id-1);
Serial.print("GET /status/alert.asp?e=
4048587609@vtext.com&id=");
Serial.println(alert_status,DEC);
Serial.println("\n\n");
if (id==0)
alert_status=0;
delay(900);
alert_status&=~(1<<(id-1));
// Initialize and start the web banner timer
ReefAngel.Timer[4].SetInterval(180); // set interval to 180 seconds
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00011000;
ReefAngel.WaterChangePorts = B00011000;
ReefAngel.WaterChangePortsE[0] = B11000000;
ReefAngel.OverheatShutoffPorts = B11000110;
ReefAngel.LightsOnPorts = B11000000;
ReefAngel.LightsOnPortsE[0] = B00100000;
ReefAngel.OverheatTempProbe = &ReefAngel.Params.Temp1;
// Return pump
// Specific functions
ReefAngel.MHLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
ReefAngel.StandardLights(Box1_Port3);
//ReefAngel.DelayedOn(Box1_Port2, 2);
ReefAngel.Relay.DelayedOn(Box1_Port2, 2);
// Turn on Port 3 when the temp of T2 gets above 85.0 degrees
if ( ReefAngel.Params.Temp2 >= 850 ) ReefAngel.Relay.On(Port3);
// Turn off Port 3 when the temp of T2 gets below 80.0 degrees
if ( ReefAngel.Params.Temp2 <= 800 ) ReefAngel.Relay.Off(Port3);
// Turn on moon lights based on moon phases between 10pm and 9am.
if ( hour() > 22 || hour() < 9)
ReefAngel.PWM.SetDaylight(100);
// Web Banner stuff
ReefAngel.WebBanner();
// Only turn on ATO for 20 minutes every hour.
if (minute()<=20)
ReefAngel.Relay.Off(Box1_Port4);
//This will send an alert if T1 is below 77 and reset if above 78
if (ReefAngel.Params.Temp1<770 && ReefAngel.Params.Temp1>0) WifiSendAlert(3,true);
if (ReefAngel.Params.Temp1>780 && ReefAngel.Params.Temp1<1850) WifiSendAlert(3,false);
//This will send an alert if T1 is above 83 and reset if below 80
if (ReefAngel.Params.Temp1>830 && ReefAngel.Params.Temp1>1850) WifiSendAlert(4,true);
if (ReefAngel.Params.Temp1<800 && ReefAngel.Params.Temp1>0) WifiSendAlert(4,false);
