Return pump cut off
Posted: Sat Jul 20, 2013 11:38 am
by windsweptfarm
Have had snails plug up syphon from overflow leading to flooding. I'm looking to have a float switch in the overflow to shut off the return pump if the overflow level and display tank level starts to crest. Very new to coding. I am hoping this is not hard to set up. Thanks, Casey
Re: Return pump cut off
Posted: Sat Jul 20, 2013 12:30 pm
Extremely easy
Posted: Sat Jul 20, 2013 2:16 pm
by windsweptfarm
Thanks so much.
Posted: Sat Jul 20, 2013 2:41 pm
Assuming you are using the ATO High port and Port8 for return, you would use something like this:
ReefAngel.Relay.Set(Port8,ReefAngel.HighATO.IsActive());
