Verification Error
Posted: Wed Jul 31, 2013 9:23 pm
Hi,
I recently tried to make a change to my INO file for my ReefAngel (note, not RA+).
It'd been a couple months since I updated libraries, so I went ahead and did that too. I was trying to add some logic around automatically turning on feedmode since I got an autofeeder.
However, when I attempted to upload this, I got the following error:
I tried a couple of the obvious things: Resetting the controller, replugging in the USB cord, restarting program, uploading a brand new memory file, checking the board type in the arduino program, removing the code I had just added. Nothing changed.
Then I went and opened the basic controller test file, and it uploaded fine.
Next, I uploaded an older version of my code, that looks like this:
This uploaded fine as well (thank god, at least I have something going on my tank now)
So, the next logical step was to start adding functionality from my updated code to the one that uploaded fine. First thing I added was the delayed start for port5.
Bingo, this now made me code fail to be verified. However, removing it from the first code still resulted in a failed upload.
Edit: and in case it matters: Binary sketch size: 31,344 bytes (of a 32,256 byte maximum)
Any pointers???
//1 Heater
//2 Moonlight
//3 Fuge Light
//4 Return
//5 Skimmer
//6 Reactor
//7 ATO
//8 LEDs -> Fan
boolean ATOTriggered = false;
unsigned long ATOTime = now();
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port1Bit;
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Timer[1].SetInterval(30);
//ReefAngel.StandardLights( Port2,21,0,11,0 );
ReefAngel.StandardLights( Port3,22,0,10,0 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.LCD.BacklightOn();
//if lights should be off, set to zero. Fallback from code above
if ((hour() < 12) || (hour() >= 20))
ReefAngel.PWM.SetDaylight(0);
if ((hour() < 11) || (hour() >= 21))
ReefAngel.PWM.SetActinic(0);
static time_t wcTimer;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE || ReefAngel.DisplayedMenu == FEEDING_MODE) wcTimer=now();
if (now()-wcTimer > 0 && now()-wcTimer < 600)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.On(Port5);
if (hour() == 8 && minute() == 0 && second() == 0)
// ReefAngel.DisplayedMenu = WATERCHANGE_MODE;
ReefAngel.FeedingModeStart();
//Moonlights with a phase of total darkness
if ((hour() >= 21 || hour() <= 2) || (hour() >= 6 && hour() <= 11))
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (!ReefAngel.HighATO.IsActive())
if(ReefAngel.LowATO.IsActive() && ATOTriggered == false)
ATOTriggered = true;
ATOTime = now();
ReefAngel.Relay.Off(Port7);
else if (ReefAngel.LowATO.IsActive() && ATOTriggered == true && (now() - ATOTime > 30 ))
ReefAngel.Relay.On(Port7);
else if (!ReefAngel.LowATO.IsActive())
// Activate Watch Dog Timer at 6am and 6pm
if ((now()%86400)==21600) delay(1000);
if ((now()%86400)==43200) delay(1000);
ReefAngel.Portal( "zechenia" );
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x7800
0x00 != 0xff
avrdude: verification error; content mismatch
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude done. Thank you.
//1 Heater
//2 Moonlight
//3 Fuge Light
//4 Return
//5 Skimmer
//6 Reactor
//7 ATO
//8 LEDs -> Fan
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.StandardHeater( Port1,771,778);
ReefAngel.PWM.SetDaylight( PWMParabola(12,0,20,0,15,55,0) );
ReefAngel.PWM.SetActinic( PWMParabola(11,0,22,0,15,52,0) );
if ((hour() < 11) || (hour() >= 22))
if ((hour() >= 22 || hour() <= 2) || (hour() >= 6 && hour() <= 11))
/* if (!ReefAngel.HighATO.IsActive())
if(ReefAngel.LowATO.IsActive())
ATOTime = now();
Any pointers???
