If Port On Then
Posted: Fri Aug 02, 2013 1:42 pm
by clw143
It seems I am not using this correctly.
// Dimmable royal blues 100% if actinics (relay port 2) are on, else moonlight
if bitRead(ReefAngel.Relay.RelayMaskOn, Port2Bit) {
ReefAngel.PWM.SetActinic( 100 );
else {
I get 100% all the time, what is the proper usage?
Re: If Port On Then
Posted: Fri Aug 02, 2013 2:09 pm
by clw143
Should it be Port1Bit for port 2?
Re: If Port On Then
Posted: Fri Aug 02, 2013 2:38 pm
Its should be 1 actually.
You are looking to read bit 0-7 to translate 1-8. I kept making that mistake a lot to use the Port2Bit
Re: If Port On Then
Posted: Fri Aug 02, 2013 2:40 pm
If you are on latest library there should be a function you can use...
ReefAngel.Relay.IsMaskOn(Port);
And also an IsMaskoff(Port)
So you dont have to worry about bits
Re: If Port On Then
Posted: Fri Aug 02, 2013 3:05 pm
by clw143
Thanks, It was a little confusing seeing this:
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
The wizard puts Port#Bit = port number, but in using the same Port#Bit in a bit read is offset by one.
Re: If Port On Then
Posted: Fri Aug 02, 2013 3:51 pm
No, the portxbit does not equal port number. It represents the bit set in binary...so port3bit = 00000100 which is equal to 4 i believe.
Re: If Port On Then
Posted: Fri Aug 02, 2013 6:22 pm
by clw143
Right, I follow, BUT then why does the wizard make a Port8Bit? It should not exist. For my water change mode above, ports 3-8 are off and Port3Bit - Port8Bit are specified.
I have version 1.0.9
It has no idea what IsMaskOn is.
Re: If Port On Then
Posted: Fri Aug 02, 2013 7:53 pm
It might still be in the dev right now, I'll check tomorrow.
The port bit is used to set things like feeding mode ports and the values are logical ORed together..
FeedingModePorts = Port1 | Port2;
Re: If Port On Then
Posted: Fri Aug 02, 2013 7:58 pm
If you look at what port3bit is lets look at the binary number again..
00000100
Now if we want to check if that bit is set we want to use bitRead to check we would read the 3rd bit counting from the right but starting at 0 as if it were an array so the first 0 on the right would be bitread(Port3Bit, 0);
The next would be bit 1 the next (Port3Bit) sould be bit 2.
Re: If Port On Then
Posted: Fri Aug 02, 2013 8:11 pm
I think you are getting confused with the number and definition of the PortXBit....
This is from Globals.h:
// Outlets on Relay box
#define Port8 8
#define Port7 7
#define Port6 6
#define Port5 5
#define Port4 4
#define Port3 3
#define Port2 2
#define Port1 1
// Port bits
#define Port8Bit 1<<7
#define Port7Bit 1<<6
#define Port6Bit 1<<5
#define Port5Bit 1<<4
#define Port4Bit 1<<3
#define Port3Bit 1<<2
#define Port2Bit 1<<1
#define Port1Bit 1<<0
Which define easier to use numbers, so we don't need to do the bit shifting or bit manipulation manually.
These numbers are meant for use on our functions.
So, Port5Bit is the same as binary B00010000, which is the same as hex 0x10, which is the same as decimal 16.
If you use a function like this:
ReefAngel.FeedingModePorts = Port4Bit;
It will be the same as this:
Now, if you look at the bitRead function here:
http://arduino.cc/en/Reference/bitRead
You will see that the function calls for a bit position and not the decimal value of where the bit is located in a byte variable.
Bit shifting and bit math can be a little confusing at first.
Re: If Port On Then
Posted: Sat Aug 03, 2013 7:55 am
clw143 wrote:Right, I follow, BUT then why does the wizard make a Port8Bit? It should not exist. For my water change mode above, ports 3-8 are off and Port3Bit - Port8Bit are specified.
I'm 99.9% sure its in there. Let me verify the syntax. I just saw someone post code that was using it at 1.0.9
Re: If Port On Then
Posted: Sat Aug 03, 2013 8:01 am
It is in the stock 1.0.9 I just confirmed.
Take a look at the class definition for Relay.
http://www.easte.net/RA/html/class_relay_class.html#
The syntax should be:
or
Make sure to change X
Re: If Port On Then
Posted: Sat Aug 03, 2013 10:51 am
by clw143
I was having some weird results and changed the code to this
if (bitRead(ReefAngel.Relay.RelayMaskOn, Port1Bit)) ReefAngel.PWM.SetActinic( 100 );
else ReefAngel.PWM.SetActinic( MoonPhase()/2 );
Moonlights should be 100% if port 2 is on, and that is quite literally how it is working, if it is in "auto" or "off" it is in moonlight mode, if "on" it is 100%
How do I get them to work right in auto?
Re: If Port On Then
Posted: Sat Aug 03, 2013 11:13 am
Use RelayData instead of RelayMaskOn
Re: If Port On Then
Posted: Sat Aug 03, 2013 11:31 am
by clw143
I try this:
if (ReefAngel.Relay.IsMaskOn(Port2);) ReefAngel.PWM.SetActinic( 100 );
Error says: 'class RelayClass' has no member named 'IsMaskOn'
Re: If Port On Then
Posted: Sat Aug 03, 2013 11:45 am
Humm..
That may have been my fault.
I think I forgot to add the entries in the features.txt file.
Hey Lee, can you create an issue and include the entries that need to added?
Re: If Port On Then
Posted: Sat Aug 03, 2013 12:18 pm
Its a lowercase is...sorry
ReefAngel.Relay.isMaskOn(Port)
My bad, no feature.txt required.
Re: If Port On Then
Posted: Sat Aug 03, 2013 3:13 pm
by clw143
This works
rimai wrote:Use RelayData instead of RelayMaskOn
This is still off for auto when auto is on and off for off, and on for on. I need on when auto on. (if that's not a confusing statement)
if (ReefAngel.Relay.isMaskOn(Port2)) ReefAngel.PWM.SetActinic( 100 );
else ReefAngel.PWM.SetActinic( MoonPhase()/5 );
