Page 1 of 2
Help needed for my DC pump automation project
Posted: Mon Aug 05, 2013 10:31 pm
by Amos Poh
Dear all need your help on the project that i have on hand. i am using DC10000 on my return and iam also running DC6000 on my RLSS skimmer, i am also using 2 x WP 40 as wave maker. Since i am using all DC pumps i was thinking y not connect it to my RA and automate it! :lol:
I am lost now as to what i have to do. Need all the advise i can get to make this work.
I have already connected the PWM dimming module to the RA and have also loaded the test code following the below instruction from the Manual:
Uploading the test code
1. Start your Arduino software
2. Open the PWM Expansion test code by going to menu File->Sketchbook->Example Codes and selecting
CustomMainScreen_PWMExpansion
3. Upload the code to your Reef Angel Controller.
Now Question is :
1)can i just cut the jebao cable connector (which is suppose to go to the Daylight or actinic dimming port)
and connect either end to channel 1 and the other to Gnd?
2)how to code if i want to run my return pump on
constant 100% in the day (12pm-10pm)
constant 80% (10pm-12am)
constant 60% (12am-12pm)
3) code it to run at 20% on feeding mode
4) do i need to change anything in the library?
Thank you all in advance ;)
Re: Help needed for my DC pump automation project
Posted: Tue Aug 06, 2013 8:29 am
by Piper
While you can certainly do this, it's not quite that simple. The pumps need a 0-5v analog signal. Your best bet is to buy the cables from RA. If you want to make them yourself check out the Eagle file for the cable in the downloads section. I made one just because I wanted to tinker and learn (and I had all the parts/pieces) and it works just fine for me.
I could be wrong here but I think the DC pumps shut down at roughly 30% if I'm not mistaken. I suspect that varies between pumps and manufacturers though.
Not as long as you're running one of the latest version of the libraries.
I did not have time to answer the rest of the questions right now but check the Jebao thread for more details on programming. I can post later tonight if nobody has answered you already.
~Charile
Posted: Tue Aug 06, 2013 8:53 am
1) If you have the RA cable, yes you need to cut the connector and connect the wires to GND and whatever channel you are trying to control.
2) Use this:
if (now()<12)
  ReefAngel.PWM.SetActinic(60);
else if (hour()>=22)
  ReefAngel.PWM.SetActinic(80);
  ReefAngel.PWM.SetActinic(100);
3) Use this:
  ReefAngel.PWM.SetActinic(20);
But read piper's comments above
4) What piper said.
Posted: Tue Aug 06, 2013 10:10 am
by Sacohen
rimai wrote: 3) Use this:
if (ReefAngel.DisplayedMenu!=FEEDING_MODE)
I have my WP-40 set to run at 20% during feeding and all night long and it is fine.
Posted: Tue Aug 06, 2013 10:14 am
How now brown cow :)
how() should be now()
And for #3 take out the ! If you want 20% during feeding mode...
rimai wrote:1) If you have the RA cable, yes you need to cut the connector and connect the wires to GND and whatever channel you are trying to control.
2) Use this:
if (how()<12)
3) Use this:
4) What piper said.
Posted: Tue Aug 06, 2013 10:18 am
HAHAHAH
I'll update the post :)
Thanks!!
Posted: Tue Aug 06, 2013 11:48 am
by Piper
I misunderstood what you were asking in Q1. You already have the RA Jebao cable and you're referring to the 2-pin connector, yes? I was envisioning you cutting the connector off of the end of your DC pump and trying to hard-wide to your dimming module :)
Good to know about the 20% on the pumps. I'll try that tonight when I get home and see if that works for me too. 30% on a WP-40 is still a bit too much during feeding mode.
~Charlie
Posted: Tue Aug 06, 2013 12:02 pm
by Sacohen
I think the percentage you can take it down to my vary depending on what mode you have it running in.
I think I remember reading or speaking to someone thru a PM that they had theirs down to 15%.
Posted: Tue Aug 06, 2013 7:14 pm
by Amos Poh
2) Use this:
if (now()<12)
3) Use this:
4) What piper said.
Roberto the code you provided is for which channel in my pwm dimming module? I am confused as the code did not indicate the channel.
Posted: Tue Aug 06, 2013 7:15 pm
by Amos Poh
lnevo wrote:How now brown cow :)
2) Use this:
if (how()<12)
3) Use this:
4) What piper said.
:lol: Thanks Lee
Posted: Tue Aug 06, 2013 7:17 pm
by Amos Poh
Piper wrote:I misunderstood what you were asking in Q1. You already have the RA Jebao cable and you're referring to the 2-pin connector, yes? I was envisioning you cutting the connector off of the end of your DC pump and trying to hard-wide to your dimming module :)
~Charlie
Thanks Charlie for contributing. I should be clearer with my post. :)
Posted: Tue Aug 06, 2013 7:18 pm
by Amos Poh
Sacohen wrote:I think the percentage you can take it down to my vary depending on what mode you have it running in.
Thanks Steve i will give it a shot.
Posted: Tue Aug 06, 2013 7:20 pm
by Amos Poh
2) Use this:
if (now()<12)
3) Use this:
4) What piper said.
Now i only need to know how to allocate channel 1 on my PWM Dimming Module to run with the above code and i am good to go :)
Posted: Tue Aug 06, 2013 10:18 pm
This is how to set the individual channel:
ReefAngel.PWM.SetChannel(1,50); // Sets channel 1 to 50%
Posted: Tue Aug 06, 2013 10:47 pm
by Amos Poh
rimai wrote:This is how to set the individual channel:
Thank you so much Roberto :)
Posted: Wed Aug 07, 2013 12:30 am
by Amos Poh
i place the code here but it didnt work not sure what went wrong.
Void loop()
ReefAngel.DosingPumpRepeat( Port2,0,60,35 );
ReefAngel.StandardLights( Box1_Port1,14,0,23,0 );
ReefAngel.RF.SetMode( Constant,50,10 );
ReefAngel.PWM.SetChannel(0,50); // Sets channel 0 to 50%
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,false) ); // Nutrient Transport on anti-sync mode
Posted: Wed Aug 07, 2013 8:38 am
You said you wanted channel 1, but you coded channel 0.
Was it intended?
Posted: Wed Aug 07, 2013 8:54 am
by Amos Poh
rimai wrote:You said you wanted channel 1, but you coded channel 0.
Was it intended?
Yes Roberto it is intended. As i hook it up to the Dimming port the first channel is 0 hence i change the code to 0 as well.
Posted: Wed Aug 07, 2013 10:24 am
Void loop shoudl be void loop? Not sure if that was a copy/paste error or something else...
What's not working?
Posted: Wed Aug 07, 2013 5:26 pm
by Amos Poh
So it should be Void loop? Instead of Void loop()?
I did a direct cut and patse.
If the code is correct then perhaps i cannot control Waveline DC10000?
Posted: Wed Aug 07, 2013 6:06 pm
No just the V shoukd be lowercase...other than that i dont know. Try reversing the wires to the pwm port.
Posted: Wed Aug 07, 2013 11:02 pm
by Amos Poh
Thanks for the advise i switch the wire on the dimming module and it WORK!
Posted: Wed Aug 07, 2013 11:08 pm
by Amos Poh
Now when i tried fixing the New Generation Waveline DC6000 on Channel 1 i realise that the connector on the pump is male! unlike the other DC pumps which is Female. so What i did was change the RA Jebao Cable to Female so i can connect to the waveline DC6000, however it didnt work on me. cant seems to control it like what i have done with the Waveline DC10000.
this is the code i use any thing wrong?
ReefAngel.PWM.SetChannel(0,100); // Sets channel 0 to 100%, DC10000
ReefAngel.PWM.SetChannel(1,100); // Sets channel 1 to 100% DC6000
Posted: Wed Aug 07, 2013 11:17 pm
by Amos Poh
Also i want to change the WP40s from daylight and actinic port to the Dimming module channel 2 and 3 how do i change the code?
Thank you so much!
Posted: Thu Aug 08, 2013 8:37 am
Oh... That's good to know the waveline has a different connector.
Yes, just change your code from actinic/daylight to channel just like you did for the other pumps :)
Posted: Thu Aug 08, 2013 9:01 am
by Amos Poh
rimai wrote:Oh... That's good to know the waveline has a different connector.
But Roberto, i cant seems to control the DC6000 as i did with the DC10000, any idea what went wrong?
As for the Code i was thinking :
ReefAngel.PWM.SetChannel( NutrientTransportMode(77,90,3000,true) );
but how to assign channel 2? :lol:
Posted: Thu Aug 08, 2013 9:17 am
ReefAngel.PWM.SetChannel( 2, NutrientTransportMode(77,90,3000,true) );
Posted: Thu Aug 08, 2013 10:17 am
by Amos Poh
rimai wrote:ReefAngel.PWM.SetChannel( 2, NutrientTransportMode(77,90,3000,true) );
Thanks :D
Posted: Thu Aug 08, 2013 8:46 pm
by Amos Poh
Ok confirm it works on my WP 40s, i have successfully hook up my DC10000(return Pump) my WP40s(wave makers) to the dimming module, however the Waveline DC6000 didnt work. anyone knows what could be the reason?
Posted: Thu Aug 08, 2013 9:24 pm
I'll let you know in a few days.
I'm getting a package of goodies from China tomorrow :)
There should be WP-25, DC-3000, DC-5000, DC-10000, DC-6000 and DC-9000 in this package :mrgreen:
