Possible relay issue??
Posted: Thu Aug 22, 2013 12:32 pm
by ecam
I have an ATI 80w 8 bulb fixture plugged into my unit. Im overriding the menu from auto to on for the lights... this will stay on and then reset to auto and turn off . Is this a possible relay issue? or normal function?
Re: Possible relay issue??
Posted: Thu Aug 22, 2013 2:17 pm
That's expected behavior when the controller reboots.
The controller is rebooting probably due to electrical noise in the expansion bus or the portal server generating an error.
There is a known bug that will be patched in the next release to prevent the controller rebooting when the portal server generates an error.
Posted: Fri Aug 23, 2013 3:43 am
by Amos Poh
ecam wrote:I have an ATI 80w 8 bulb fixture plugged into my unit. Im overriding the menu from auto to on for the lights... this will stay on and then reset to auto and turn off . Is this a possible relay issue? or normal function?
Is 80w x 8 too much for the relay to handle?
