Dosing Pump Question
Posted: Sat Aug 31, 2013 2:48 pm
So I finally added a relay expansion and can now plug in my two doing pumps. So how should I set this up, hard code it or adjust though the portal.
Has the final lnevo/kirkwood code been posted somewhere, I would love to be able to track the dosing.
If I add the code can I then adjust through the portal, will that over ride the code ??
Still using digital timers for my dosing until I can figure this out, unless I'm over thinking this.
Chris
Chris
