float sensor time delay - new question
Posted: Sun Sep 01, 2013 3:35 pm
by rossbryant1956
Been following a post from a user about a situation where he wants the ATO to NOT turn on until the float sensor has been tripped for few seconds and it is sure the tank needs a decent amount of water. Roberto suggested this bit of code:
static time_t LastATO=millis();
if (!ReefAngel.LowATO.IsActive()) LastATO=millis();
if (millis()-LastATO<5000 && millis()-LastATO>100)
ReefAngel.Relay.Off(Port1);
ReefAngel.SingleATO(true,Port1,10,0);
I use a different method of monitoring my float switches. How would I add Roberto's code to it?
//turn on GT Fill when switch is tripped
ReefAngel.Relay.Set(GT_Fill,ReefAngel.IO.GetChannel(2));
Variable GT_Fill, of course, is the name of my ATO pump. Thx
Re: float sensor time delay - new question
Posted: Mon Sep 02, 2013 1:31 pm
Try this:
if (!ReefAngel.IO.GetChannel(2)) LastATO=millis();
ReefAngel.Relay.Off(GT_Fill);
ReefAngel.SingleATO(true,GT_Fill,10,0);
Posted: Mon Sep 02, 2013 4:45 pm
by rossbryant1956
are we sure about that last line? Not using SingleATO.
Posted: Mon Sep 02, 2013 5:00 pm
I simply changed the LowATO.IsActive() for IO.GetChannel(2).
I don't know what you want to do.
Try it and see if it works.
Posted: Mon Sep 02, 2013 5:11 pm
by rossbryant1956
OK...as always thx very much for your help!!
Posted: Wed Sep 04, 2013 3:42 pm
by rossbryant1956
1. my wires are down, should I be using false instead of true in that code line?
2. what does the 10 stand for? Run for 10 seconds and stop? 10 minutes?
thx
Posted: Thu Sep 05, 2013 8:21 am
Yes, remove the ! if you have the float wires down.
10 is 10 seconds for ATO timeout.
Posted: Thu Sep 05, 2013 4:07 pm
by rossbryant1956
yes to both?
yes - change true to false
AND
yes - remove the !
Posted: Thu Sep 05, 2013 5:14 pm
Ahh. Now I saw what you mean by true or false...
Please look here for a quick view of what each parameter in the function is about:
http://www.easte.net/RA/html/class_reef ... 545a376e92
And here is the code for it:
https://github.com/reefangel/Libraries/ ... .cpp#L1364
bLow is for true for Low ATO port and false for High ATO port.
The ! sign means not:
http://arduino.cc/en/Reference/Boolean
So, if (!ReefAngel.IO.GetChannel(2)) means if Channel 2 is not active and if (ReefAngel.IO.GetChannel(2)) means if Channel 2 is active.
Active means the float switch contacts are closed.
Posted: Sat Sep 21, 2013 4:52 pm
by rossbryant1956
Still need your help. I tried this code both ways, using both the ! you originally suggested and just now took out the ! and tried it again. Of course, if that 5000 in the code means wait 5000 seconds before actually doing anything then I didn't count to 5000
if (ReefAngel.IO.GetChannel(2)) LastATO=millis();
Plus I still really don't understand the use of true and false in the SingleATO line. Thx again.
Posted: Sat Sep 21, 2013 5:45 pm
true is Low ATO port and false is High ATO port. It tells which port you are using for ATO.
5000 is 5000 milliseconds.
Posted: Sat Sep 21, 2013 6:05 pm
by rossbryant1956
any idea why this is not working?
Posted: Sat Sep 21, 2013 6:20 pm
Can we start over... I just re-read the thread, and I have no clue what you're trying to accomplish. What does GT_Fill mean?
What was the ATO code you were using before you added this delay that worked? I feel like you copied Roberto's sample code and it may not fit the original needs. You stated you weren't using SingleATO... and both your wires are pointed down.
Lee
Posted: Sat Sep 21, 2013 6:58 pm
by rossbryant1956
Thanks Lee;
I do a series of things with the I/O expansion unit and float valves. Here is some of my working code:
// I_O Expansion & Float Valves
ReefAngel.CustomVar[7]=1;
//turn off DT pump when switch is tripped and sound buzzer
ReefAngel.Relay.Set(DT_Pump,ReefAngel.IO.GetChannel(0));
ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0); //tell the portal we have a overflow problem
//turn off GT pump when switch is tripped and sound buzzer
ReefAngel.Relay.Set(GT_Pump,ReefAngel.IO.GetChannel(1));
ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(1)*100));
ReefAngel.CustomVar[1]=ReefAngel.IO.GetChannel(1); //tell the portal we have a overflow problem
In other words, when those I/O floats trip, they turn off the pumps DT & GT to keep those tanks from overflowing. I have had trouble in the past with my Glass-Holes overflows slowing due to junk in the pipes. Works like a charm. Then I added another float valve to my I/O expansion, wires pointed down, that would turn on another pump and refill evaporated water from my RODI system. I originally used this line of code:
ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(2)*100));
Worked like a charm. THEN under the auspices of one of the primary engineering tenets "if it ain't broke, fix it anyway" I decided it would be better to implement some method of instead of toggling that pump every time that tank needed a little water it would be better to have it wait until it needed a decent top off before turning on.
So that's where I am. Roberto suggested a bit of code that seems like it should work but I'm not able to understand it well enough to do my own troubleshooting. Appreciate any advice you provide. Thanks
Posted: Sun Sep 22, 2013 11:42 am
by rossbryant1956
bump...any thoughts?
Posted: Sun Sep 22, 2013 11:51 am
Yeah, sorry no I haven't had a chance to look at it yet... so what does GT_Fill mean (just so it's clear in my brain...
And the code you had before.. what is the SetDaylight command doing? is that for a buzzer? or something else?
Posted: Sun Sep 22, 2013 12:21 pm
by rossbryant1956
GT_Fill is the name of my pump on a relay. And don't worry about the buzzer, I am in the midst of changing that to your WiFiAlert code. Basically I want it to alert me when the pump comes on (and goes off)
Thx, Lee
Posted: Sun Sep 22, 2013 12:49 pm
So is GT_Fill always running unless the switch is tripped?
Posted: Sun Sep 22, 2013 12:52 pm
Also, is the LowATO switch involved or just the Channel 2 on the expansion?
I think it's not working because Roberto assumed you were using the ATO switch as well...
Posted: Sun Sep 22, 2013 1:44 pm
by rossbryant1956
No GT_Fill is off unless tripped by channel two and then no LowATO at all only the expansion and the float valve
Posted: Sun Sep 22, 2013 2:16 pm
Ok, yeah, so that's why this isn't working... the SingleATO function is not made to be used by other channels...
Roberto should actually fix that
Instead of taking a boolean it could take an int where 0 is high, 1 is low, rest are remaining channels... That would fix that..
In the meantime, let me look at that code soon...
Posted: Tue Oct 01, 2013 7:17 pm
by rossbryant1956
Okay I have been working with your switchalert code and it is now working beautifully with my I/O expansion. This is how I modified it:
void CheckSwitches() {
static boolean GT_OverFillOverride=true;
static WiFiAlert switchAlert, skimmerAlert;
skimmerAlert.SetDelay(3600);
switchAlert.SetDelay(3600);
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
// Turn off GT_OverFill if sump overflowing
if (!ReefAngel.IO.GetChannel(3)) {
if (!GT_OverFillOverride) {
switchAlert.Send("GT_Sump+level+alarm!+MixPump+disabled.");
ReefAngel.Relay.Override(GT_OverFill,0);
} else {
GT_OverFillOverride=false;
So in this app, when that float valve trips, it sends the wifialert and turns off GT_Overfill (my pump.) I can then use the portal or the web app to reset that relay once the obstruction is cleared.
So my question is in another application I'd like to use this same snip of code but would like the relay sent back to "auto" automatically once the obstruction is cleared. Is there a way to do that? As always thanks in advance.
Posted: Tue Oct 01, 2013 7:55 pm
Are you sure you want to go back on automatically?
Posted: Tue Oct 01, 2013 8:04 pm
I would just put the relay back in auto mode from your phone once the obstruction is clear....
Posted: Tue Oct 01, 2013 8:15 pm
by rossbryant1956
Post by lnevo ยป Tue Oct 01, 2013 10:04 pm
For the application above that will work fine. For the new app
Yes I do. Roberto, this is that app we did some time ago for my overflows that would slow but not stop up. I want the pumps to turn off while the overflow is catching up but then to come back on once clear. If I have to, I can continue using my existing code but I really like the work Lee is doing and trying to improve my coding style.
Remember this?
Thanks again
Posted: Tue Oct 01, 2013 8:36 pm
So in the else section where GTOverride=false add the following line
ReefAngel.Relay.Override(GT_OverFill,2);
