pressure actuated level sensor ATO
Posted: Tue Sep 10, 2013 1:17 pm
by juszczyk
Picture below so that it's clearer to understand. I'm currently using a Tsunami ATO, which uses a pressure sensor to turn on/off ATO. The Tsunami has a module which the pressure sensor 1/4 hose and water pump plug into. This module then plugs into the Relay Box. I also use high single float switch to turn off Relay Box plugin in case of malfunction.
The issue: The Relay Box plug is currently always on so that the Tsunami module does the on/off work for ATO and then single float for malfunction turn off Relay Box plug.
Since the Relay Box plug is always on, is there a way for the RA to know when the Tsunami turns on? This way I could put a timer say 30 seconds for pressure switch ATO and have two malfunction safeties. One in case Tsunami does not turn off and second the high float switch.
Re: pressure actuated level sensor ATO
Posted: Tue Sep 10, 2013 1:51 pm
Nope, unless you use another sensor to monitor if the water level is changing.
