I set the dip switches to on|off|off, which should be correct for a second relay expansion, I have the new code uploaded and on the portal and my Android app they show up but they do not turn on and are not controllable.
I just verified all of the dip switches and I verified that it could work by setting the dip switches to off|off|off and making it think it was my 1st expansion. It copied the function of the first expansion at that point fine so the hardware is good, I just must be missing something on the software end of things.
Copy of my code below, not sure what I am missing though, hopefully someone can help out.
//// Ports toggled in Feeding Mode
// Turns off Skimmer(Port2), Small Koralia (Port4), and Large Koralia (Port6)
ReefAngel.FeedingModePorts = Port2Bit | Port4Bit | Port6Bit;
// Turns off GFO/Carbon Reactor during feeding
ReefAngel.FeedingModePortsE[0] = Port6Bit | Port5Bit;
//// Ports toggled in Water Change Mode
// Turns off Skimmer (Port2) and Return Pump (Port7)
ReefAngel.WaterChangePorts = Port2Bit | Port7Bit;
// Turns off Heater (Port[0]1), Heater (Port[0]2, Reactor Pump (Port[0]6), and ATO (Port[0]8)
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port6Bit | Port8Bit;
//// Ports turned off when Overheat temperature exceeded
// To Turn Off: Frag Tank Light (Port1), Dosing Alk (Port3), Dosing Calcium (Port4), Large Koralia (Port6)
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port6Bit;
// To Turn Off: Heater (Port[0]1), and Heater (Port[0]2)
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
//// Use T1 probe as temperature and overheat functions
// This is the Probe in the Display Tank, Probe 2 is for the Room, and Probe 3 is in the Frag Tank
//Empty
ReefAngel.Relay.On( Box2_Port7 );
//Empty
ReefAngel.Relay.On( Box2_Port8 );
// Skimmer
ReefAngel.Relay.On( Port2 );
//Frag Tank Pump
ReefAngel.Relay.On( Port3 );
//Small Korilia
ReefAngel.Relay.On( Port4 );
//Return Pump to DT
ReefAngel.Relay.On( Port7 );
//Power to 3rd Relay
//Small Koralia near Vortech
//GFO and Carbon Reactor
//Vortech
//ATO Plug
//Ground
ReefAngel.Relay.On( Box2_Port1 );
//Frag Tank Koralia Pumps
ReefAngel.Relay.On( Box2_Port6 );
// Frag Tank Lights
ReefAngel.DayLights( Port1 );
// Alk Dosing
ReefAngel.DosingPumpRepeat1( Box1_Port3 );
//Calcium Dosing
ReefAngel.DosingPumpRepeat2( Box1_Port4 );
//Large Korilia
ReefAngel.WavemakerRandom( Port6,10,20 );
//Heater
ReefAngel.StandardHeater( Box1_Port1 );
//Heater
ReefAngel.StandardHeater( Box1_Port2 );
//LED Light 1400mA
ReefAngel.StandardLights( Box2_Port2,6,0,21,0 );
//LED Light 1400mA
ReefAngel.StandardLights( Box2_Port3,6,0,21,0 );
//LED Light 700mA
ReefAngel.StandardLights( Box2_Port4,6,0,21,0 );
//LED Light 700mA
ReefAngel.StandardLights( Box2_Port5,6,0,21,0 );
//PWM Daylight Dimming
//PWM Actinic Dimming
ReefAngel.RF.UseMemory = true;
if ( ( (hour()==9) && (minute()==30) ) || ( (hour()==19) && (minute() ==30) ) )
{ReefAngel.FeedingModeStart();
ReefAngel.Relay.Set(Port5,now()%60<4);}
{ReefAngel.Relay.Off(Port5);}
ReefAngel.Portal( "vonjankmon" );
int x,y;
// Relay Expansion
