Adding Code for Power Control expansion
Posted: Thu Sep 19, 2013 12:30 am
by jcondello
Hi cant work out out how to get my Power control expansion up and going i have attached the current code i'm using, where and how do i code it to initialize it.
thank you in advance.
Re: Adding Code for Power Control expansion
Posted: Thu Sep 19, 2013 8:46 am
The module works as if it were a relay expansion module.
So, you can use Box1_Port1 for example to reference to Port1 on the module.
You can even use the wizard and pick relay expansion module.
