Has anyone created or can create a quick program to change the PWM values of the dimming module on the fly to check to see what the flicker point of the LED/controller's are? Just the minimum value before the controller light up the LED's is what I'm chasing.
I was thinking of something that would change every 2 seconds or so maybe?
PWM Value Checker
- lnevo
Re: PWM Value Checker
You can overwrite the channels manually and find the point without a program.
http://www.xxx.yyy.zzz:2000/poX,Y
Where x is the id of the channel and y is the value you want. Set to 255 to reset to default.
0 is actinic and 1 is daylight i believe. Higher than that are the ports on the dimming channel
dlplunkett44
Can this be done with the 16 channel dimming expansion? If so what would "X" be? Could you do 12-bit (up to 4095)?
- Contact:
not sure off hand, but you can look at the libraries and find out.
RA_Wifi.cpp is the file that contains all the wifi commands that are available. it's inside the libraries folder.
