Dosing Question - Lee
Posted: Thu Sep 26, 2013 10:53 am
by ecam
// Define Your dosing pumps
#define numDPumps 2
byte pumpRelays[numDPumps]={ Port4, Port6 };
int DPVolume[numDPumps]={ 30, 30 } ; // 30ml for each alk and calcium
int DPRepeat[numDPumps]={ 60, 60 } ; // Repeat every 60 miniutes
// Define Calibration here
int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 300, 178 }; // 300ml / 178ml
// Function: RunDosingPumps()
void RunDosingPumps() {
  float rate;
  int calcTime[numDPumps];
  for (int i=0;i < numDPumps; i++) {
    rate=(float)CalVol[i]/CalTime[i];
    calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
    // Run the pumps
    ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
  // Display Time calculated in portal
  ReefAngel.CustomVar[0]=calcTime[0];
  ReefAngel.CustomVar[1]=calcTime[1];
// Function: LogDosingPumps()
void LogDosingPumps() {
  static time_t pumpTimer[numDPumps];
  static boolean pumpStatus[numDPumps];
  float rate;
  for (int i=0;i< numDPumps;i++) {
    if (ReefAngel.Relay.Status(pumpRelays[i])) {
      if (!pumpStatus[i]) {
        pumpStatus[i]=true;
    } else {
      if (pumpStatus[i]) {
        pumpStatus[i]=false;
        // Report How much volume has been dosed per day.
        // Could make this in minutes... excercise for the reader..
        ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
        ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
    // Clear timer at end of day
    if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
Since the reef angel logs the volume being dosed daily. Will I be able to see a chart of this with my reef angel website? if not... is their anyway i can make it do so... The reason i want this is because i figured if I fill up a gallon bucket and can go back and check how long did it does over the month. I can notice when I may need to adjust my calibration due to the pump changing its pump rate
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer=0;
Re: Dosing Question - Lee
Posted: Thu Sep 26, 2013 11:38 am
Yes my code is logging through the ReefAngel.CustomVar[] and you can get the graph from the portal. However the portal only stores 7 days so you wont be able to see the full month, unless you log it yourself or use reeftronics.net :)
The only issue I've had with the logging I have is that I get a bit under what I put in which may just be rounding errors..
Posted: Thu Sep 26, 2013 12:23 pm
by ecam
Is there anything special i need to do to feed data to reeftronics.
Posted: Thu Sep 26, 2013 12:25 pm
by ecam
Also, i was looking through your custom pde and I want to "borrow" so much of it. Especailly the reminders. However, how do i get around your use of "memory" to use code like i like to use. Or to get to your code, do i have to go to the dark side of the force ("memory") :twisted: :lol:
Posted: Thu Sep 26, 2013 1:05 pm
The dark side of the force is not that dark...all you need is the #define lines I use. But yes the reminders rely on memory otherwise if you load code or your controller resets then you would lose everything you saved.
You could just use variables though if you really wanted to avoid it...
Posted: Sat Sep 28, 2013 7:10 pm
by ecam
#define numDPumps 2
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml
  float rate;
    // Run the pumps
    ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
  float rate;
        pumpStatus[i]=true;
    } else {
lee, im gettigng a variable not expected before'{' token... any idea how to fix it
Posted: Sat Sep 28, 2013 8:18 pm
It's somewhere else in your code. I took that section and added the #include files and a blank setup() and loop() function and it compiles fine.
Can you post the full code please?
Posted: Sat Sep 28, 2013 8:37 pm
by ecam
#include <DS1307RTC.h>fafa
#include <RF.h>fa
  byte myRFMode=0;
    byte myRFDuration=0;
    byte myRFSpeed=0;
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
    // Setup ATO Port for AI communication
//    ReefAngel.AI.SetPort( lowATOPin );
    ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
    ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
    ReefAngel.Relay.On( Box1_Port5 ); // MP40s
    ReefAngel.Relay.On( Box1_Port6 ); // JBJ
  //  Port1 Return pump...  on all the time!!!
      ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
  //  Port3 ...  not used
      ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
      ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
      ReefAngel.StandardLights( Port6,10,0,20,0 );  //ATI Fan
      ReefAngel.StandardHeater( Port7,778,790 ); //Heater
      ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
      //box 2
      ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used   Port #9
 //   Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
      ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11
              if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
              if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
 //   Box1_Port4 Ecotech MP_40 Pumps  on all the time!!!      Port #12
 //   Box1_Port5 Razor_LED (Sump)...  on all the time!!!      Port #13
 //   Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
     ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
     ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
//    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
//    ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
//    ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
    ReefAngel.RF.SetMode( ReefCrest,85,10 );
  //  ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
  //  ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
  //  ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
  //  ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
  //  ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
 //   ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
  //  if ( second()==0 ) ReefAngel.RF.RadionWrite();
#define numDPumps 2
  float rate;
    // Run the pumps
  float rate;
        pumpStatus[i]=true;
    } else {
      if (hour()>=6 && hour()<11)
        myRFSetMode(ReefCrest,85,10);
      else if (hour()>=11 && hour()<13)
      else if (hour()>=13 && hour()<16)
        myRFSetMode(Smart_NTM,85,15);
      else if (hour()>=16 && hour()<19)
        myRFSetMode(ReefCrest,65,10);
        myRFSetMode(Lagoon,40,10);
    // Hardcode PH calibrations
     //ReefAngel.PHMin=544; // PH7.0
     //ReefAngel.PHMax=830; // PH10.0
    ReefAngel.Portal( "ecam" );
    int x,y;
    // Aqua Illumination
    x = 10;
    y = 20;
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
    for ( int a=0;a<3;a++ )
      ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
      x += 38;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
    // Main Relay Box
    // Date and Time
    void myRFSetMode(byte m, byte s, byte d)
      if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
        myRFMode=m;
        myRFSpeed=s;
        myRFDuration=d;
        ReefAngel.RF.SetMode(m,s,d);
Posted: Sun Sep 29, 2013 4:23 am
That section that you originally posted does not go inside the loop() function. It's 2 functions and some global variables. It all goes at the bottom. And add only the function calls to the loop()
     RunDosingPumps();
     LogDosingPumps();
Try this:
#include <RF.h>fa
  byte myRFMode=0;
    byte myRFSpeed=0;
      //box 2
     RunDosingPumps();
     LogDosingPumps();
    int x,y;
    x = 10;
    y = 20;
      x += 38;
    // Parameters
    // Main Relay Box
    // Date and Time
#define numDPumps 2
  float rate;
    // Run the pumps
  float rate;
        pumpStatus[i]=true;
    } else {
        myRFMode=m;
        myRFSpeed=s;
        myRFDuration=d;
Posted: Sun Sep 29, 2013 10:18 am
by ecam
Okay so i loaded this code. where do i go to see the log update. do i go to the portal the head unit or ipad app. how can i get it to show up on the portal
lnevo wrote:That section that you originally posted does not go inside the loop() function. It's 2 functions and some global variables. It all goes at the bottom. And add only the function calls to the loop()
     RunDosingPumps();
     LogDosingPumps();
Try this:
#include <RF.h>fa
  byte myRFMode=0;
    byte myRFSpeed=0;
      //box 2
     RunDosingPumps();
     LogDosingPumps();
    int x,y;
    x = 10;
    y = 20;
      x += 38;
    // Parameters
    // Main Relay Box
    // Date and Time
#define numDPumps 2
  float rate;
    // Run the pumps
  float rate;
        pumpStatus[i]=true;
    } else {
        myRFMode=m;
        myRFSpeed=s;
        myRFDuration=d;
Posted: Sun Sep 29, 2013 10:35 am
You should see it in the portal under the custom variables. If you want to see over time go to http://forum.reefangel.com/status/chart ... &filter=C2
Change C2 to C3 to see the other pump.
Posted: Sun Sep 29, 2013 10:48 am
by ecam
I dont see anything that would include custom variables anywhere. in the portal, it isnt dependant on memory is it?
