2nd Relay with no power
Posted: Sat Sep 28, 2013 9:58 am
by Rodasphoto
I just uploaded the following code to my RA+ and none of the equipment is working. I tried resetting the controller by unplugging it and reconnecting it. When I reconnected it the red light on the controller kept flashing until I disconnected the relay expansion module from the expansion hub and reset the controller.
[quote]
#include <Globals.h>
#include <RA_Wifi.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <[color=#006699]LED[/color].h>
#include <RA_TempSensor.h>
#include <[color=#006699]Relay[/color].h>
#include <RA_PWM.h>
#include <[color=#006699]Timer[/color].h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
    [color=#7E7E7E]// This must be the first line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color]();  [color=#7E7E7E]//Initialize controller[/color]
    [color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port4Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePortsE[/color][0] = [color=#006699]Port3Bit[/color] | [color=#006699]Port4Bit[/color];
    [color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port3Bit[/color] | [color=#006699]Port4Bit[/color] | [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePortsE[/color][0] = [color=#006699]Port4Bit[/color];
    [color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port2Bit[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPortsE[/color][0] = [color=#006699]Port1Bit[/color];
    [color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port3Bit[/color] | [color=#006699]Port4Bit[/color] | [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPortsE[/color][0] = [color=#006699]Port3Bit[/color];
    [color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#7E7E7E]// Set the Overheat temperature setting[/color]
    [color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 840 );
    [color=#7E7E7E]// Ports that are always on[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port1[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Box1_Port3[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Box1_Port8[/color] );
    [color=#7E7E7E]////// Place additional initialization code below here[/color]
    [color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port2[/color],9,0,21,10 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port3[/color],9,0,21,30 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port4[/color],9,0,21,30 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]WavemakerRandom1[/color]( [color=#006699]Port5[/color],30,100 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]WavemakerRandom2[/color]( [color=#006699]Port6[/color],30,100 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port7[/color],778,784 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Box1_Port1[/color],9,0,21,40 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Box1_Port4[/color],9,0,21,0 );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 0, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,100,0) );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 1, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,100,0) );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 2, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,100,2) );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 3, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,75,0) );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 4, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,75,0) );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 5, [color=#CC6600]PWMParabola[/color](9,0,21,0,0,60,3) );
    [color=#7E7E7E]////// Place your custom code below here[/color]
    [color=#CC6600]if[/color] (hour()<9 || hour()>=21)
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color]([color=#006699]Port5[/color]);
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color]([color=#006699]Port6[/color]);
    [color=#7E7E7E]////// Place your custom code above here[/color]
    [color=#7E7E7E]// This should always be the last line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"Rodasphoto"[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawCustomMain()
    [color=#CC6600]int[/color] x,y;
    [color=#CC6600]char[/color] text[10];
    [color=#7E7E7E]// Dimming Expansion[/color]
    x = 15;
    y = 2;
    [color=#CC6600]for[/color] ( [color=#CC6600]int[/color] a=0;a<6;a++ )
      [color=#CC6600]if[/color] ( a>2 ) x = 75;
      [color=#CC6600]if[/color] ( a==3 ) y = 2;
      [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,x,y,[color=#006699]"Ch :"[/color] );
      [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a );
      [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetChannelValue[/color](a) );
      y += 10;
    [color=#CC6600]pingSerial[/color]();
    [color=#7E7E7E]// Parameters[/color]
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 39, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color],
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color]() );
#else [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 39, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color] );
#endif [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
    [color=#7E7E7E]// Main Relay Box[/color]
    [color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
    TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
    TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 76, TempRelay );
    [color=#7E7E7E]// Relay Expansion[/color]
    TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayDataE[/color][0];
    TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOffE[/color][0];
    TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOnE[/color][0];
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 96, TempRelay );
    [color=#7E7E7E]// Date and Time[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color]( 6, 122 );
[color=#CC6600]void[/color] DrawCustomGraph()
[/quote]
Re: 2nd Relay with no power
Posted: Sat Sep 28, 2013 3:13 pm
by Rodasphoto
Just checked everything and the RA has jumpers in and the relay expansion module has the dip switches set to id 2.
Sent from my SCH-I535 using Tapatalk 4
Posted: Sat Sep 28, 2013 7:50 pm
Needs to be set to id1
Posted: Sun Sep 29, 2013 10:28 am
by Rodasphoto
That did it. But now my controller does not seem to react to my inputs from the reef Angel app until I disconnect my pwm dimming module and reset the controller.
Posted: Sun Sep 29, 2013 2:58 pm
So, your wifi doesn't work when you connect the dimming module?
Posted: Sun Sep 29, 2013 3:44 pm
by Rodasphoto
Everything works for a while then the wifi module's orange light blinks and the red status light blinks on my RA+ controller. I disconnect the PWM usb from the expansion module the wifi module starts working again. Some time passes and the whole cycle repeats itself I disconnect the PWM module, ...., etc.
Posted: Sun Sep 29, 2013 6:25 pm
by Rodasphoto
Oh my lights are not gradually dimming like I have them programmed to. I just disconnected the pwm module and reconnected them back into the expansion module and the lights dimmed to the level it is suppose to be at.
Posted: Sun Sep 29, 2013 7:03 pm
Have you tried updating the wifi firmware?
Does the dimming module work without the wifi?
Also, you may want to try adding this to your code:
  wdt_enable(WDTO_8S);
Posted: Mon Sep 30, 2013 2:51 am
by Rodasphoto
I have not updated the firmware on my WiFi module. How do I update it?
I just wanted to confirm I add the code you gave me in the custom code section. What does it do?
I'll disconnect the WiFi module and see if the lights dim properly. I will let you know.
Posted: Mon Sep 30, 2013 11:06 am
It will increase the watchdog. I'm thinking you are having some of the problems that others have had and this code fixed it.
The watchdog patch is in the next release of libraries.
You can place the code in the setup() section, right after ReefAngel.Init();
Just make sure it is after and not before.
Posted: Sun Oct 13, 2013 7:38 am
by Rodasphoto
rimai wrote:It will increase the watchdog. I'm thinking you are having some of the problems that others have had and this code fixed it.
Should it look like this?
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port6Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port4Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.StandardLights( Port2,9,0,21,10 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom1( Port5,30,100 );
    ReefAngel.WavemakerRandom2( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.StandardLights( Box1_Port1,9,0,21,40 );
    ReefAngel.StandardLights( Box1_Port4,9,0,21,0 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,21,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,100,2) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,21,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,21,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,21,0,0,60,3) );
    if (hour()<9 || hour()>=21)
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 96, TempRelay );
    // Date and Time
Posted: Sun Oct 13, 2013 8:08 am
Yeah :)
Posted: Sun Oct 13, 2013 8:51 am
by Rodasphoto
I cannot connect to my WiFi module. The green light blinks followed by the orange light. I tried resetting the RA by cycling the power. I am currently on 1.07. Should I update the libraries? You mentioned updating the firmware for the WiFi, how do I go about updating it?
Posted: Sun Oct 13, 2013 7:27 pm
Did you check if the router didn't assign the wifi attachment a new ip address?
Posted: Mon Oct 14, 2013 7:43 pm
by Rodasphoto
The WiFi module shows up as a wireless client on my router (apple airport extreme). I can connect to the controller for a couple of hours and then a get a bad URL error message. Then the lights don't dim properly. If I try to reset the controller with my pwm module connected it wont reset. I have to disconnect my PWM module then disconnect the controller to reset it.
Posted: Wed Oct 16, 2013 9:40 pm
Do you want to try the new libs?
Posted: Fri Oct 18, 2013 7:21 pm
by Rodasphoto
Yes. i really miss being able to control the RA from my phone.
Posted: Sat Oct 19, 2013 8:17 am
Download the latest dev branch: https://github.com/reefangel/Libraries/archive/dev.zip
Unzup it.
Replace your folder \Documents\Arduino\libraries with the one you downloaded.
Upload your code again.
Posted: Sat Oct 19, 2013 9:37 am
by Rodasphoto
I just updated the libraries and uploaded the code again. Now the green light on the wifi module blinks and I am still unable to connect.
Posted: Sat Oct 19, 2013 12:10 pm
by dbmet
Have you run the wifi utility?
Posted: Sat Oct 19, 2013 12:16 pm
by Rodasphoto
dbmet wrote:Have you run the wifi utility?
I ran it when I first received the Wi-Fi module.
Posted: Mon Oct 21, 2013 4:45 pm
by Rodasphoto
Updated the firmware and reran the wifi utility. Everything seemed for OK. But when I woke up today the system was not responsive. I had to unplug my PWM module and power off the RA controller to get it to unfreeze then plugged my PWM module back in. I don't know what else to do.
Posted: Mon Oct 21, 2013 5:34 pm
Are you sure you updated the libraries with the dev branch?
Posted: Mon Oct 21, 2013 5:48 pm
by Rodasphoto
I downloaded the files you asked me to took the old libraries out and placed the new ones in its place. I will retry it tomorrow and check back with my results.
Posted: Tue Oct 22, 2013 5:39 pm
by Rodasphoto
I just reloaded the code with the new libraries. The arduino software states its version 1.0.9. Keeping my fingers crossed and hoping this time everything works as it should.
Posted: Thu Oct 24, 2013 9:53 am
by Rodasphoto
Reloaded the new library and eureka it works.
