How to code alk cal dosing pumps beyond basic wizard setup..
Posted: Sun Sep 29, 2013 6:13 pm
by DavidinGA
I setup two dosing pumps using the reef angel wizard and they have worked fine thus far; but I would like to be able to control exactly what time each day I dose by stating a time rather than the wizard way of doing it (dose for xx seconds every 60min or whatever).
Right now my 2 dosing pumps are port 7 and 8 below in the code.
ReefAngel.DosingPumpRepeat( Port7,0,480,25 );
ReefAngel.DosingPumpRepeat( Port8,0,480,24 );
So every 480 minutes they come on for 25sec and 24sec. How can I change this to a time format where I can put in say to dose port7 at 7:00am for 25 seconds then again at 7:00pm for 25 seconds and then something similar for port8
    ReefAngel.StandardHeater( Port1,795,800 );
    ReefAngel.StandardHeater( Port2,793,800 );
    ReefAngel.StandardLights( Port3,1,0,24,0 );
    ReefAngel.StandardLights( Port4,11,0,21,0 );
    ReefAngel.DosingPumpRepeat( Port6,0,240,600 );
    ReefAngel.DCPump.SetMode( LongPulse,40,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,80,10 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,60,5 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ShortPulse,70,10 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( ReefCrest,60,20 );
else if (hour()>=16 && hour()<22)
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // Parameters
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
    // Main Relay Box
    // Date and Time
Re: How to code alk cal dosing pumps beyond basic wizard set
Posted: Sun Sep 29, 2013 6:57 pm
You can use something like this:
if ( (hour()==7 && minute()==0 && second()<25) || (hour()==19 && minute()==0 && second()<25) )
  ReefAngel.Relay.On(Port7);
  ReefAngel.Relay.Off(Port7);
Posted: Sun Sep 29, 2013 7:18 pm
by DavidinGA
rimai wrote:You can use something like this:
Ok.
If I do that do I leave my original code like it is and add your new code?
...or do I need to change it?
....and
Do I put that code right after ////// Place your custom code below here where my other custom code is?
NEW CODE IN HERE?
if (hour()<8)
Posted: Sun Sep 29, 2013 7:22 pm
Yes, place where you mentioned, but you must remove the old code.
Posted: Sun Sep 29, 2013 7:27 pm
by DavidinGA
rimai wrote:Yes, place where you mentioned, but you must remove the old code.
