2nd temp probe
Posted: Sat Oct 05, 2013 3:36 pm
by Elevatorguy1
Just received my second temp probe to use for display temp. Do you just plug into one of the temp ports or do you need to add code to get a reading displayed on the portal and android app?
Re: 2nd temp probe
Posted: Sat Oct 05, 2013 6:20 pm
Plug in and reboot controller. One issue to keep in mind though is that the ports are assigned by serial number to t1, t2, t3 respectively. So the new one you plug in *could* takeover as t1
Re: 2nd temp probe
Posted: Sun Oct 06, 2013 9:07 am
by Elevatorguy1
That did it. Thanks lnevo! Also, in the android app you need to go to settings-controller info-visibility and check the temp2 box.
