How to control 2 WP-40s and a DC6000 with the DCPUMP class?
Posted: Mon Oct 21, 2013 4:12 pm
by Smotz
Hi all,
I have 2x WP40s and a DC6000 DC return pump. My current code is listed below (I haven't implemented the return pump yet). I will be adding the DC6000 using the modified Jebao cable for ATO.
How can I set a different setting for the return pump than what I have set for my WP-40?
For instance, I want to turn the DC6000 off during feeding mode but keep my WP-40's on 30%.
ReefAngel.DCPump.FeedingSpeed=30;
Re: How to control 2 WP-40s and a DC6000 with the DCPUMP cla
Posted: Mon Oct 21, 2013 4:19 pm
Dont use the dc pump class for the return pump. Use it through the PWM class the way we used to.. Put an if feeding mode then set to whatever % or 0.
Posted: Mon Oct 21, 2013 4:25 pm
by Smotz
Gotcha. I am debating on not using the DCPUMP class all together coz of the memory increase - I don't use the portal to control my wave makers. Can you think of any other benefit?
Posted: Tue Oct 22, 2013 6:25 pm
by Smotz
lnevo wrote:Dont use the dc pump class for the return pump. Use it through the PWM class the way we used to.. Put an if feeding mode then set to whatever % or 0.
Hey dude, would you be able to elaborate a bit? What would the command be to use the PWM class with the ATO? would this be it:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,45*2.55);
the above would set it to 45% ? If so - whats with the * 2.55 ?
To take it further - how can I set the value for this in internal memory so I can change it when I want?
Posted: Tue Oct 22, 2013 6:45 pm
Yes, that's it.
*2.55 is because the controller uses a range from 0-255, but we humans use 0-100 so, we need to multiply by 2.55.
If you want to use internal memory, you can do something like this:
    analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
Then use the android app to change the value you want to use.
Posted: Tue Oct 22, 2013 7:08 pm
by Smotz
rimai wrote:Yes, that's it.
Nice - sorry for the barrage of questions but I have more :)
What memory location would I change for this? I don't quite understand LEDPWMActinic_read .. ?
Can I set a default value - say 50% ? that gets changed via the droid app - I would want that value to stick should I reboot, etc ... is that possible ?
Posted: Tue Oct 22, 2013 7:14 pm
Yeah, just use android app and set the memory location PWM Actinic to 50. Internal memory is persistent, so it doesn't get erased when power is lost.
Posted: Tue Oct 22, 2013 7:16 pm
by Smotz
rimai wrote:Yeah, just use android app and set the memory location PWM Actinic to 50. Internal memory is persistent, so it doesn't get erased when power is lost.
Nice. Thx man.
