WiFi lost connectivity!!!
Posted: Fri Oct 28, 2011 11:28 pm
by acabano
WiFi lost connectivity and never recovers after so many web refresh.
steps that already been taken..
1. factory RESET
2. use static instead of dhcp
3. set connection timeout to 1
4. use Graphical-Wifi-Utility
5. i just updated Libraries to the latest with Reef Angel Libraries Update Utility
seems like the wifi module is in some kind of timeout?
Re: WiFi lost connectivity!!!
Posted: Sat Oct 29, 2011 9:00 am
Has it always been like this or started recently?
It seems to be the same problem that Curt was having with one of the units he had.
He'd loose connectivity.
He sent me the unit for examination and I've had on and serving webpages for about a week and it never dropped on me as of yet.
htt://betatest.reefangel.com:2000
It's even tucked inside my drawer to try to make it a weaker signal, but that didn't seem to have made any difference.
So, I'm not sure what the problem really is. The only thing I could think of is possibly router to wifi issues, but he also has a second wifi attachment that has been working fine for him on the same router.
Here is another thing you can try doing:
1. Connect the wifi attachment to USB-TTL cable and use your prefered terminal softwate, such as Ter-Term, putty or any other.
2. Use commands:
These commands will download the latest firmware from the manufacturer ftp server and update the module.
If it still doesn't work, send me a PM for RMA.
Posted: Sat Oct 29, 2011 11:56 am
by acabano
I notice this before but not that often.
ok, i did the ftp and still having same problem...
<2.28> ftp u
<2.28> FTP connecting to 208.109.78.34
FTP file=50
FTP OK.
UPDATE OK
<2.28>
<2.28>
<2.28>
<2.28> ver
WiFly Ver 2.28, 09-08-2011 on 131C83
<2.28>
Posted: Sat Oct 29, 2011 12:04 pm
Does any LED stay on or blink, besides the usual slow green blink?
Posted: Sat Oct 29, 2011 5:46 pm
by acabano
If i use the leave command, all ligths will blink, same with the join command.
connection will establish and then drop and never recover..
