ReefAngel.LightsOn(); during feeding then off when exit
Posted: Sat Oct 26, 2013 3:22 pm
by Smotz
Hi All,
Can someone help me with this?
I want to turn my my ReefAngel.LightsOn(); when I enter feeding mode and water change mode but then I want the lights to go off when I exit the mode.
I can turn the lights on but how to I turn them off - I was thinking :
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else ReefAngel.LightsOff();
But (logically speaking) that will turn my lights off all the other times. - Don't want that
any thoughts?
Re: ReefAngel.LightsOn(); during feeding then off when exit
Posted: Sat Oct 26, 2013 5:03 pm
You don't need the else.
Also, instead of LightsOn(), use Relay.On(Port1)
Posted: Sat Oct 26, 2013 5:26 pm
by Smotz
rimai wrote:You don't need the else.
but that wont turn it off when the mode is exited..
Posted: Sat Oct 26, 2013 6:31 pm
Is it a fact or speculation?
If fact, please post your code.
Posted: Sat Oct 26, 2013 6:46 pm
by Smotz
rimai wrote:Is it a fact or speculation?
speculation. Let me test..
Posted: Sat Oct 26, 2013 7:20 pm
The reason it won't stay on is that the Relay.On is actually overriding your StandardLights function.
The order is important though.
The StandardLights has to come before your if statement.
If positioned like that, when you enter water change mode, the Relay.On function will force the port to be on instead of whatever StandardLights is setup for.
When not in water change mode, the StandardLights will still control the port on/off as normal.
Posted: Sat Oct 26, 2013 8:11 pm
by Smotz
rimai wrote:The reason it won't stay on is that the Relay.On is actually overriding your StandardLights function.
I actually don't have a StandardLights statement.
how should I have that formatted? (code below)
//// Port 1 Heater
//// Port 2 ATO pump
//// Port 3 NOT USED Reactor Pump
//// Port 4 Protien Skimmer
//// Port 5 Return Pump
//// Port 6 Wavemaker
//// Port 7 UV Sterilizer
//// Port 8 Fan
//// BOX 1 PORT 8 Fuge Light
#define Heater Port1
#define Topoff Port2
// #define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define Fan Box1_Port8
#define FugelightBit 1<<7
#define UVlightBit 1<<6
#define WaveBit 1<<5
#define ReturnBit 1<<4
#define SkimmerBit 1<<3
// #define ReactorBit 1<<2
#define TopoffBit 1<<1
#define HeaterBit 1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
ReefAngel.FeedingModePorts = SkimmerBit | ReturnBit | TopoffBit;
ReefAngel.WaterChangePorts = HeaterBit | SkimmerBit | ReturnBit | TopoffBit | WaveBit;
ReefAngel.LightsOnPorts = FugelightBit;
ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | SkimmerBit | ReturnBit | WaveBit;
// Use T1 (SUMP) probe as temperature and overheat functions
//ReefAngel.WaterLevel.GetLevel
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Wave );
ReefAngel.StandardHeater( Heater );
//ReefAngel.StandardATO( Topoff );
ReefAngel.MoonLights( Fugelight );
ReefAngel.StandardFan( Fan );
ReefAngel.SalMax=InternalMemory.SalMax_read();
// if the hour is 6a and minute is 58 and seconds is 0
// start the feeding mode
if ( ((hour() == 6)) &&
(minute() == 58) &&
(second() == 0) ) {
ReefAngel.FeedingModeStart();
// end feeding mode
/// If PH is higher than 8.4 disable the auto top off
if (ReefAngel.Params.PH>840) ReefAngel.Relay.Off(Topoff);
ReefAngel.Relay.DelayedOn(Skimmer,2);
// Custom Wave Routine
// set the wpMode based on what time it is
if ( (hour() >= 2) && (hour() < 5) ) wpMode=2; // from 2am - 5am
if ( (hour() >= 5) && (hour() < 8) ) wpMode=1; // from 5am - 8am
if ( (hour() >= 8) && (hour() < 11) ) wpMode=2; // from 8am - 11am
if ( (hour() >= 11) && (hour() < 14) ) wpMode=3; // from 11a - 2pm
if ( (hour() >= 14) && (hour() < 17) ) wpMode=2; // from 2pm - 5pm
if ( (hour() >= 17) && (hour() < 20) ) wpMode=1; // from 5pm - 8pm
if ( (hour() >= 20) && (hour() < 23) ) wpMode=2; // from 8pm - 11p
if (hour() >= 23) wpMode=3; // from 11pm - midnight
if (hour() < 2) wpMode=3; // from midnight - 2am
// set the Wave Strength based on wpMode
if (wpMode==1) wpWavStr=45;
if (wpMode==2) wpWavStr=50;
if (wpMode==3) wpWavStr=55;
//Set the Wave OffSet
wpWavOff=15;
ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,true) );
ReefAngel.PWM.SetActinic(wpWavStr);
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Relay.On(Fugelight);
// end Custom Wave Routine
// DC Return Pump using internal memory
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
// END DC Return Pump
// Only turn on UV Sterilizer between 11pm and 4am
if ( (hour() >= 4) && (hour() < 23) ) // from 4a - 11p
ReefAngel.Relay.Off(UVlight);
else ReefAngel.Relay.On(UVlight);
ReefAngel.Portal( "Smotz" );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 5, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 5, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,20,80, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,44,80, ReefAngel.Params.Salinity );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 105, TempRelay );
// Date and Time
//draw the mode on the screen
char buf[16];
char buf2[16];
char buf3[32];
sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
sprintf(buf2,"Wave Mode = %d%",wpMode);
sprintf(buf3,"Return Power = %d%",InternalMemory.LEDPWMActinic_read());
ReefAngel.LCD.DrawText(0,255,10,40,buf3);
ReefAngel.LCD.DrawText(0,255,20,60,buf);
ReefAngel.LCD.DrawText(0,255,20,50,buf2);
Posted: Sat Oct 26, 2013 8:14 pm
FugeLight (Port8), right?
Same thing. You are using MoonLights()
I think it looks good. Did you try?
Posted: Sun Oct 27, 2013 8:05 am
by Smotz
rimai wrote:FugeLight (Port8), right?
Yup - it works. Thanks for your help, as always.
