ATO Adjustment
Posted: Sun Oct 27, 2013 7:51 pm
by AnthonyK
I've been trying myself to code this but just not having any luck with it.
I have a Standard ATO and need to set a code so that the pump isn't recycling on and off repeatedly when the water splashes in the sump.
How do I code the ATO pump to turn on only when the LowATO is active for at least 5 seconds? Appreciate any help I can get. Thanks
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 6:12 am
The code Roberto gave you in this thread is not working?
http://forum.reefangel.com/viewtopic.php?t=3944#p33300
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 6:13 am
Also... If you are using StandardATO then it should be using two float switches...spread them out a bit more because the standard ato function fills until the high switch is up and does not turn back on until low is back down...
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 2:09 pm
by AnthonyK
No, I couldn't get that code to work.
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 2:10 pm
Did it not compile? Or did it not do what you needed?
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 2:14 pm
by AnthonyK
It was only doing the part that said turn on for xx minutes every yy minutes. It ignored the low ato isactive part.
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 2:46 pm
Impossible... unless you're code was in wrong, or the code needing that needed to be reversed depending on your switch status... can you post the code you used (full INO)
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 6:13 pm
by AnthonyK
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Clear Overheat";
prog_char menu4_label[] PROGMEM = "Fuge Lights";
prog_char menu5_label[] PROGMEM = "PH Calibration";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label  };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
;ReefAngel.WaterChangeModeStart();
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.Relay.Override(Port7, ReefAngel.Relay.Status(Port7)+1);
void MenuEntry6()
ReefAngel.SetupCalibratePH();
    ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardHeater( Port3,775,780 );
    ReefAngel.StandardLights( Port4,9,0,21,0 );
    ReefAngel.StandardLights( Port7,21,0,9,0 );
    ReefAngel.StandardLights( Port8,10,0,20,0 );
    ReefAngel.StandardATO( Box1_Port1,600 );
    ReefAngel.StandardLights( Box1_Port2,1,0,13,0 );
    ReefAngel.StandardFan( Box1_Port3,785,790 );
    ReefAngel.DCPump.SetMode( ReefCrest,70,25 );
  ReefAngel.DosingPumpRepeat(Box1_Port1,0,10,60);
  ReefAngel.Relay.Off(Box1_Port1);
    int x,y;
    // "Sammy's Reef"
    ReefAngel.LCD.DrawLargeText (12, 255,18,8,"Sammy's Reef");
    // Salinity Display
    ReefAngel.LCD.DrawLargeText(0,255,15,30,"Salt");
    ReefAngel.LCD.DrawLargeText(2,255,15,40,"1.025");  //(Delete this line when sensor is installed)
    //ConvertNumToString(text,ReefAngel.Params.Salinity, 1000); (add this line when sensor is installed)
    //ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,15,40,text,Num8x8); (add this line when sensor is installed)
    // Water Level Display
    /// To be added when expansion is purchased
    // Left Power Head Display (Actinic)
    ReefAngel.LCD.DrawLargeText (0,255,15,50,"L Wave");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_BLUE,15,60,1);
    //Right Power Head Display (Daylight)
    ReefAngel.LCD.DrawLargeText (0,255,75,50,"R Wave");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_BLUE, 75, 60, 1); //<Color, Pos From Right, Pos From Top, Decimal Placement>
    // Temperature Display
    ReefAngel.LCD.DrawLargeText(0,255,15,70,"Temp");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 15, 80, text, Num8x8);
    // PH Display
    ReefAngel.LCD.DrawLargeText(0,255,75,70,"pH");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 75, 80, text, Num8x8);
    // Main Relay Box
    // Relay Expansion
    // Date and Time
Re: ATO Adjustment
Posted: Mon Oct 28, 2013 6:14 pm
by AnthonyK
It may be working now, I have to wait and see but looks it's been set this way for the afternoon and not gone above the low ato switch yet.
I added the {}brackets to the if and else code...could that have made a difference?
