Could you take a glance at this? (Code help)
Posted: Thu Oct 31, 2013 10:24 am
Im having problems with my lights . I want my daylight lights (port3) to gradually dim on in the mornings starting at say 11 AM and eventually dim completely off around 8 pm. Everyday my lights both daylight and actinic channels are completely off until around noon everyday. Here is what i want to happen but i cant seem to figure out what im doing wrong.
Everyday:
Actinic channel (port4)
on : 7:30 AM
off : 10:35 pm
daylight (port3)
start coming on at 11 AM @ 5% gradually brighten up to 75% peak (parabola) and then gradually go back down throughout the day to 0% at 8:00pm
Moonlight(port2)
On: 10:30 PM
Off : 7:35 AM
Everyday:
on : 7:30 AM
off : 10:35 pm
daylight (port3)
Moonlight(port2)
On: 10:30 PM
Off : 7:35 AM
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.StandardLights( Port2,22,30,11,0 );
ReefAngel.StandardLights( Port3,12,0,20,30 );
ReefAngel.StandardLights( Port4,11,0,22,35 );
ReefAngel.WavemakerRandom( Port5,5,60 );
ReefAngel.WavemakerRandom( Port6,19,37 );
ReefAngel.SingleATO( false,Port7,66,0 );
ReefAngel.StandardHeater( Port8,770,791 );
ReefAngel.PWM.SetDaylight( PWMParabola(12,0,20,0,0,70,0) );
pinMode(lowATOPin,OUTPUT);
if (InternalMemory.LEDPWMActinic_read()<=100)
analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
analogWrite(lowATOPin,MoonPhase()*2.55);
ReefAngel.Portal( "Dctrojan" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
/code]
