Controll ORP
Posted: Thu Nov 07, 2013 2:14 pm
Is it possible to control the ozone generator with a ORP expansion to a specific level. Type to shut off if it gets too high and turns on when it gets too low?
https://forum.reefangel.com/
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port4,17,0,20,0 );
ReefAngel.Relay.DelayedOn( Port5,5 );
ReefAngel.StandardHeater( Port6,249,255 );
ReefAngel.Relay.DelayedOn( Port8,5 );
if (ReefAngel.Params.ORP>=400)ReefAngel.Relay.Off(Port3);
if (ReefAngel.Params.ORP>=300)ReefAngel.Relay.On(Port3);
ReefAngel.DCPump.SetMode( ReefCrest,65,10 );
ReefAngel.Portal( "anderzon_" );
if (ReefAngel.Params.ORP >= 400 ) ReefAngel.Relay.Off(Port3);
if (ReefAngel.Params.ORP <= 300 ) ReefAngel.Relay.On(Port3);
