Page 1 of 2
Why does my RA go into feeding mode randomly
Posted: Thu Nov 14, 2013 11:03 pm
by modulok
Happened last week one night while sleeping. Around 4am I awoke to the unpleasant sound of my tanks pumps shutting off and overflow water noise.
I updates some code (heater temps and light schedule) yesterday and libraries updated too.
The happened again yesterday around 3am, and it just happened tonight around 1230am, twice. I just killed power to both relays and did full reset.
I'm getting worried sincere it's cooler in the house and heaters are needed now. Water change mode shuts off heaters.
Sent from my Nexus 7 using Tapatalk 4
Re: Why does my RA go into water change mode randomly at nig
Posted: Fri Nov 15, 2013 1:14 am
by Pny
Since the problems started after a code update, I would guess its a software problem... I suggest you go back to the previous code and libraries and see if the problem disappear...
Posted: Fri Nov 15, 2013 4:23 am
by modulok
No... It happened before the code update too.
Posted: Fri Nov 15, 2013 5:40 am
Lets see your code...could you be hitting an overheat maybe? Also i would suggest a portal key.
Posted: Fri Nov 15, 2013 10:52 am
by modulok
It's definitely not an overheat. I don't shut off my return pump on overheat.
Portal key for blocking someone starting water changes without my knowledge? Thank god I didn't have some type of auto water change setup.
// Define Named Relay Ports
#define Flow1 1
#define Flow2 2
#define Flow3 3
#define Return 4
#define Skimmer 5
#define VortechL 6
#define VortechR 7
#define HeaterDisp 8
#define CenterT5 Box1_Port1
#define FrontT5 Box1_Port2
#define BackT5 Box1_Port3
#define MoonLED Box1_Port4
#define Unused Box1_Port5
#define Reactor Box1_Port6
#define Fan Box1_Port7
#define HeaterSump Box1_Port8
// Custom Main
byte x,y;
////// Setup Begin
// Controlled Modes Toggled Ports
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit; //Flow1-3,Return,Skimmer,HeaterDisp
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port7Bit | Port8Bit; //FrontT5,Fan,HeaterSump
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit; // Flow1-3,Return,Skimmer,HeaterDisp
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; //Front+BackT5,Reactor,Fan,HeaterSump
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit; //Center+Front+BackT5
// Water Temperature Settings & Overheat
ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterDisp
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port8Bit; //Front+BackT5,HeaterSump
ReefAngel.Relay.On( Flow1 );
ReefAngel.Relay.On( Flow2 );
ReefAngel.Relay.On( Flow3 );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( VortechL );
ReefAngel.Relay.On( VortechR );
ReefAngel.Relay.On( Reactor );
// Ports that are always off
ReefAngel.Relay.Off(Unused);
//5 second timer for power outage detection
ReefAngel.Timer[1].SetInterval(5);
////// Setup End
////// Loop Begin
// Ports that are Delayed
ReefAngel.Relay.DelayedOn( Skimmer,2 );
// Temperature Control
ReefAngel.StandardHeater( HeaterDisp,770,775 );
ReefAngel.StandardHeater( HeaterSump,767,772 );
ReefAngel.StandardFan( Fan,810,814 );
// T5 Light Schedule
ReefAngel.StandardLights( CenterT5,9,0,20,0 );
if (hour()==14 && minute()>=0 && minute()<=59) ReefAngel.Relay.Off(CenterT5);
ReefAngel.StandardLights( FrontT5,10,0,18,0 );
ReefAngel.StandardLights( BackT5,11,0,19,0 );
// RSM MoonLED Schedule
if (hour()>=6 && hour()<=8) ReefAngel.StandardLights( MoonLED,6,0,8,59 ); //Morning
else if(hour()>=20 && hour()<=23) ReefAngel.StandardLights( MoonLED,20,0,23,45 ); //Evening
else if(hour()>=23 || hour()<=4) if (MoonPhase()>=90) ReefAngel.StandardLights( MoonLED,23,46,4,0 ); //Full Moon
// Moonphase LED Schedule
if (hour()>=21 || hour()<4)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
//T5 Light Off Variable
//if (hour()==12 && minute()>=30 && minute()<=44) ReefAngel.Relay.Off(CenterT5);
//if (hour()==12 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
//if (hour()==16 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
//if (hour()==13 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
//if (hour()==16 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
// Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=16 && hour()<=19)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(LongWave,50,30);
else if (hour()>=20 || hour()<7)
ReefAngel.RF.SetMode(Lagoon,20,0);
ReefAngel.RF.UseMemory=true;
// When Return pump is off so is Skimmer
if (!ReefAngel.Relay.Status(Return)) {
ReefAngel.Relay.Override(Skimmer,0);
ReefAngel.Portal( "modulok" );
////// Loop End
void CheckPower() {
static boolean PowerOutage=false;
static boolean DelayedPowerOutage=false;
// Power Outage - Leave Single Flow Pump Powered
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) PowerOutage=true; //Expansion Relay 1 has lost power
if (!PowerOutage)
ReefAngel.Timer[1].Start();
if (ReefAngel.Timer[1].IsTriggered())
DelayedPowerOutage=true;
if (DelayedPowerOutage)
ReefAngel.Relay.Off (Flow1);
ReefAngel.Relay.Off (Flow3);
ReefAngel.Relay.Off (Return);
ReefAngel.Relay.Off (Skimmer);
ReefAngel.Relay.Off (VortechL);
ReefAngel.Relay.Off (VortechR);
ReefAngel.Relay.Off (HeaterDisp);
// Power Restored
if (PowerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
PowerOutage=false;
LastStart=now();
////// Custom Main Begin
// Display Date & Time
ReefAngel.LCD.DrawDate(5, 2);
// Display Water Temp Value
ReefAngel.LCD.DrawHugeNumbers(COLOR_CRIMSON, 255, 5, 14, text);
// Display pH Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,80,14,"pH");
// Display pH Value
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 95, 14, text, Num8x16);
// Display Room Temp Text
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,80,24,"Rm");
// Display Room Temp Value
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16);
// Vortech Info
//Moon Phase
ReefAngel.LCD.Clear(DefaultBGColor,5,88,95,95);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,88,MoonPhaseLabel());
//Dimmable Moon LEDs
ReefAngel.LCD.DrawText(COLOR_NAVY,255,5,98, "MoonLEDs:");
ReefAngel.LCD.Clear(DefaultBGColor,59,98,75,106);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98, "%");
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox( 2, 107, TempRelay );
ReefAngel.LCD.DrawOutletBox( 2, 119, TempRelay );
////// Custom Main End
////// Custom Graph Begin
///// Custom Graph End
Posted: Sun Nov 17, 2013 5:46 pm
by modulok
Happened again, but at 8am this morning. When I went all the way over in the RA Android App I did notice the Vortech's were in Feeding mode, so it may not be water change, but feeding mode instead. Any ideas?
Posted: Sun Nov 17, 2013 7:26 pm
Do you have any equipment that is cycling such as wavemakers?
Posted: Mon Nov 18, 2013 6:01 am
by KRavEN
I've had an auto-topoff float switch connected to a relay and it kept cycling the relay a bunch when I had my hands in the sump and that caused it to happen to me. The relay causes a surge that could be picked up by the AVR as a button press.
Posted: Mon Nov 18, 2013 7:31 am
by modulok
Happened again last night, it was feeding mode, which after 15mins everything went back to normal. Could be happening when I am not around as well.
I am leaving town for a few days and removed the ports for water change mode, I also changed feeding mode just to turn off return & skimmer. I also updated the RA code with the portal key on Sunday, but it didn't help the auto feed mode at 1am.
No cycling equip or ATO switches being used.
Re: Why does my RA go into feeding mode randomly
Posted: Fri Dec 27, 2013 1:25 pm
by javisaman
having the exact same problem. Did you fix this?
Posted: Fri Dec 27, 2013 4:48 pm
by modulok
My *fix* was to set the feeding mode ports over to water change.
Posted: Fri Dec 27, 2013 5:27 pm
That's one way to skin a cat...
Posted: Tue Jan 14, 2014 2:49 pm
by modulok
Roberto, can we look into this issue? There are a few of us who are having the issue, and for me it's annoying that I have to workaround the problem and lose one of the great features of my RA.
I still have some ports the toggle off during feeding mode, so I can look at the history.
Posted: Wed Jan 15, 2014 11:26 am
I'm unable to replicate which makes it very difficult to get to a solution.
What I'm thinking is something in your environment that is causing this.
It could be an equipment connected to your RA or even RF noise, who knows.
Have you tried unplugging equipment to see if the problem stops?
Posted: Fri Jan 17, 2014 10:43 am
by modulok
I will try turning the Vortechs off and unplugging the RF module over the weekend and see if I get any random feeding modes.
Posted: Thu Jan 23, 2014 10:41 am
by goisles1
I've had the same problem and I think I know the cause for mine... If I let my filter sock go too long, i get much more turbulance in my sump. This causes the the RA to go into Feeding mode.
It was happening recently and once I swapped out my sock for a clean one, it stopped. Also, I find if I'm moving things around in the sump it triggers it as well.. Example.. Last night I organized my wiring in the sump and knocked into the return line a few times.. RA went into Feeding mode twice.
Of course this only explains what causes it.. not WHY it actually occurs
Posted: Thu Jan 23, 2014 8:15 pm
by javisaman
I still haven't fixed this issue, but it has reduced in frequency since I replaced my RA board. Which accessories do you guys have?
I suspect it maybe either the expansion hub and or the relay expansion module that is causing the issue.
Posted: Sun Jan 26, 2014 2:52 pm
by modulok
I've had the RF Exp unplugged since Monday, and as I look at the portal relay activity chart, I don't see any abnormal equip off during a feeding mode that wasn't true. I will plug it back in and see if I get the issue again.
I have the following equip:
Relay Exp
Exp Hub
RF Exp
2x Vortechs
Posted: Tue Jan 28, 2014 9:39 pm
by javisaman
I was just about to post this. I unplugged my RF module and the random feeding modes have stopped. Anyone else can confirm this?
Roberto, do you know what could be causing this?
Posted: Tue Jan 28, 2014 9:51 pm
There may be other RF interference that is being pick up then.
Posted: Wed Jan 29, 2014 11:05 pm
by javisaman
Do you mean between the RF unit and the head unit? Since, there are a number of users that are affected by this particular issue it seems unlikely that we all are affected the same way. How is it that the RF module is turning on feeding mode on the head unit? Is there a way we can figure out what could be causing the interference?
Posted: Thu Jan 30, 2014 9:07 am
I'm not so sure what is causing that.
I cannot replicate the issue, so I can only assume that the issue is local to your environment.
Posted: Thu Jan 30, 2014 2:18 pm
by javisaman
Well my argument was that it isn't just local to my environment since a few of the members here are having the same problem. Nevertheless, I can understand why this particular issue is difficult to replicate. My confusion is how the RF module is even switching the head unit into feeding mode. I originally suspected if it was the RF module interfering with the Wi-Fi module some how, but uplugging the wi-fi module did not stop the random feeding modes. I'm curious to know if it's the RF signal that's generated or usb noise from the module .
Posted: Thu Jan 30, 2014 3:37 pm
We have quite a few RF modules out there that do not present a behavior like that.
It looks to me that is something that you guys have in common that we still have not found out what it is.
I also do not know why the feeding mode is triggered.
Does the vortech also enter feeding mode? Does it show a blinking white button?
Posted: Thu Jan 30, 2014 8:00 pm
by javisaman
Yes it's a true feeding mode, not just turning on the feeding mode relays, with a timer and everything. I can even turn off the feeding mode with the portal/android app. The vortech pump goes into feeding mode.
I am using an vortech MP40 ES wireless. I haven't really encountered the problem in the past, it started happening about a couple of months ago after I updated the library and code on the reef angel.
Posted: Fri Jan 31, 2014 9:59 am
Did it happen right after the update?
Have you tried downgrading the libraries?
Did you happen to download and install a new RA installer from the website?
I'm wondering if it is related to the twi.c....
Let's try this:
Download the attached twi.c and overwrite the one you have in your computer.
The file is located here: C:\Program Files (x86)\Reef Angel Controller\libraries\Wire\utility\twi.c
Upload code to your controller again.
Posted: Fri Jan 31, 2014 8:30 pm
by javisaman
Can't say it happened right after, but at least it started happening around the same time I updated the code. I was having issues with the VGA cables, causing the relays to not turn on reliably. I had tried updating the libraries reflashing the head unit to no avail, but was able to fix the issue by replacing the cables.
I will try that change and report back to you in a couple of days with the RF module plugged in again. Before unplugging the module, it was randomly going into feeding mode about 3-4 times a day.
Posted: Sat Feb 01, 2014 8:09 am
by modulok
I don't understand how the RF module can initiate a feeding mode.
The only other RF I have in the area is a Roku controller. Could that be interfering with the module?
Posted: Sat Feb 01, 2014 10:08 am
RF signals are everywhere...cordless phones, any electronic device, garage door openers...its everywhere
Posted: Sat Feb 01, 2014 2:37 pm
by javisaman
I'm using OSX Mavericks and I don't see the Wire directory in the same directory as the other libraries (ReefAngel, ReefAngel_Features, etc). Am I looking at the right place?
update: actually doing a search I can't even find the twi.c file
