Wifi help
Posted: Sun Nov 17, 2013 9:19 am
by Scott B
I just got my RA yesterday and have been trying to hook the wifi attachment to it. The wifi attachment will not connect to my network, both the green and blue lights are flashing. It says unable to setup port forwarding... Am i doing something wrong?
Re: Wifi help
Posted: Sun Nov 17, 2013 1:56 pm
by Scott B
Wow!!! i guess nobody monitors the forum?? does anyone have experience setting these up? and yes i have searched the forums but have not found anything that helps...
Re: Wifi help
Posted: Sun Nov 17, 2013 2:15 pm
you don't have to have port forwarding enabled or setup for the wifi to work. port forwarding is needed if you are outside of your network. have you used the wifi setup utility?
Sent from my Moto X
Re: Wifi help
Posted: Sun Nov 17, 2013 3:07 pm
by Scott B
yes i used the wifi setup utility and thats what told me that. it would not setup with the utilty
Re: Wifi help
Posted: Sun Nov 17, 2013 3:27 pm
if the utility doesn't work for you, then you will most likely have to setup the module manually using teraterm. maybe Roberto has some other ideas or comments about the utility.
Sent from my Moto X
Re: Wifi help
Posted: Sun Nov 17, 2013 4:28 pm
Make sure you are using WPA2-PSK with AES encryption.
Also, the passphrase and SSID are case sensitive.
Re: Wifi help
Posted: Sun Nov 17, 2013 9:04 pm
by Scott B
Sorry, but i am computer illiterate, lol. I probably shouldnt have purchased this controller with such little computer knowledge. Any way, im not sure about my router... it says WPA WPA2 Personal. I did enter the ssid and key/password exactly as it appears. And i am not sure what or how to download "tera term"
Re: Wifi help
Posted: Sun Nov 17, 2013 10:22 pm
Does the ssid or passphrase have a space?
I've seen where it was an issue in the past.
Also, if possible, try changing your router to WPA2 Personal with AES encrytion. TKIP encryption is only supported if you use WPA1.
Re: Wifi help
Posted: Mon Nov 18, 2013 9:24 am
by Scott B
How do i change my router settings, lol?
Re: Wifi help
Posted: Mon Nov 18, 2013 9:36 am
by johniii
Try typing 192.168.0.1 in your web address bar. With Most routers this brings you to the settings
Re: Wifi help
Posted: Wed Nov 20, 2013 7:33 am
by fatman
Scott, I sent you a PM with my phone. Give me a call and we can work out the WiFi thing.
Fat
Re: Wifi help
Posted: Wed Nov 20, 2013 11:02 am
by Scott B
Ok, i changed router to wpa2 personal with aes. It still will not connect. It says unable to setup port forwarding. I try to download teratem, but it just takes me to wireless|microchip tecnology website... i dont see where/ or how to download "teraterm"
Re: Wifi help
Posted: Wed Nov 20, 2013 12:30 pm
Not all routers offer UPnp for port forwarding.
Is your module still showing blue led?
Re: Wifi help
Posted: Wed Nov 20, 2013 5:00 pm
by Scott B
Yes, still blinking blue and green..
