Display screen black not responding to joystick
Posted: Thu Nov 21, 2013 10:52 pm
by Jbowen590
The display screen started out looking glitchy but I was still about to go through all the menues. Then it cleared the picture but wouldn't change from it's home screen. Now it's completely black and will not respond to any joystick function. Tried resetting and reloading code no change. Please help.
Re: Display screen black not responding to joystick
Posted: Thu Nov 21, 2013 10:58 pm
PM for RMA
Posted: Thu Nov 21, 2013 11:11 pm
by Jbowen590
Private message you?
Posted: Thu Nov 21, 2013 11:59 pm
by Jbowen590
Says I'm not allowed to use private messaging. Do I need to have a certain amount of post to use this feature?
Posted: Fri Nov 22, 2013 2:30 am
You need one more...
Posted: Fri Nov 22, 2013 2:55 am
by Jbowen590
I figured it would be 5 thanks for the info. Let's see if it works.
Posted: Sun Jan 26, 2014 11:26 am
by c_wick
I'm having the same issue, my screen went blank last night and now it won't turn back on. I've reset the controller, the green power light comes on but no LCD screen
Posted: Sun Jan 26, 2014 11:36 am
Is the controller still turn on/off relays?
Posted: Sun Jan 26, 2014 11:43 am
by c_wick
No, it's no longer running its program
Posted: Sun Jan 26, 2014 11:44 am
Can you upload codes to it?
Posted: Sun Jan 26, 2014 11:52 am
by c_wick
I tried but nothing happen. The arduino software looked to be uploading, it said done uploading but the controller didn't flash, it just stays constant green light on the power
Posted: Sun Jan 26, 2014 11:57 am
Did you look for any sign of water damage?
Posted: Sun Jan 26, 2014 12:04 pm
by c_wick
I don't see any water damage but there was a rattling sound inside so I opened it up and one of the metal brackets that the power cable screws in to to keep it in place was jostling about. Do you think that could have shorted sometime on the board?
Posted: Tue Jan 28, 2014 10:43 am
by c_wick
Roberto, i'm wondering if I should purchase a new head unit board or if I should get a new LCD display? Would the LCD display being out affect my lights not turning on, or would that be controlled by the board?
Posted: Tue Jan 28, 2014 10:51 am
If the unit is not controlling anything and it is not accepting code upload, it is most likely the head unit board.
If it was just the screen, the controller would still be working.
Posted: Tue Jan 28, 2014 11:39 am
by c_wick
Ok thanks Roberto I'm going to order a new board then. Always appreciate the help.
Posted: Tue Jan 28, 2014 11:43 am
by c_wick
One last question, if I upgrade to the head unit plus is there any change as far as wires and cables to what I have now or is it just more memory? I have the gen 1 LCD display so would that still be compatible?
Posted: Tue Jan 28, 2014 11:55 am
Yes, screen is compatible.
It's a swap replacement with nothing to be changed, except the head unit board.
Posted: Mon Feb 10, 2014 3:27 am
by Jbowen590
Installed the new screen and this is what it's doing. Image
Any suggestions?
Posted: Mon Feb 10, 2014 9:14 am
Yeah, your board is setup to use the gen3 screen.
Use this code right above ReefAngel.Init();
  InternalMemory.LCDID_write(255);
Posted: Tue Feb 11, 2014 4:24 am
by Jbowen590
this is what my code looks like and screen hasn't changed.
Posted: Tue Feb 11, 2014 8:58 am
I'm sorry man....
I made a mistake....
Gen 3 screens need this:
  InternalMemory.LCDID_write(0);
Posted: Tue Feb 11, 2014 7:21 pm
by Jbowen590
Thanks that did the trick. Working great now.
