Wifi Attachment stopped working
Posted: Fri Nov 22, 2013 6:28 am
by ReEfnWrX
So my WIFI attachment stopped working around 7:30 last night. I have verified that it still has a reserved IP as well as port forwarding. The green light is a slow pulse... which if I recall means it has an IP address
I tried connecting it to my laptop to reconfigure it and i get this message when I click connect
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
Re: Wifi Attachment stopped working
Posted: Fri Nov 22, 2013 9:43 am
Are you able to ping the module?
Posted: Fri Nov 22, 2013 11:36 am
by ReEfnWrX
Yes
Posted: Fri Nov 22, 2013 5:37 pm
by ReEfnWrX
Also, when I plug in the wifi attachment it automatically slow blinks green. None of the other colors blink. If I recall correctly, orange and blue would flash atleast once when initially plugged in and establishing wifi connection.
Posted: Fri Nov 22, 2013 6:30 pm
Those are not supposed to blink.
If you can ping but it is still not able to connect with browser or smart phone, I think you will need to send it back for analysis.
PM me for RMA.
