I have not looked into the RA Wizard to see if this is possible yet, but I am wondering the following:
I want to setup a single float switch in my ATO reservoir so that when it's low on water it can send me an alert on my phone (via SMS/text/email... something) and turn off a certain relay socket (keep the pump from running when there is no water).
Is this covered in the wizard or will I need to do some research and write this code myself?
And finally, regarding the single float switch... I've looked at the user manual and can not determine how to position a single float switch for proper operation. Do I want the threads/nut side of the switch UP (fig A below) or DOWN (fig B below)?
Basic float switch question
AJ
AJ
Re: Basic float switch question
For this purpose, you can mount whichever way you wish.
Use this for A:
Or this for B:
Then, you can set the portal to alert you using the ATOLOW as a trigger.
Just keep in mind that the portal only receives data every 5 minutes.
Use this for A:
ReefAngel.Relay.Set(Port1,!ReefAngel.LowATO.IsActive);
ReefAngel.Relay.Set(Port1,ReefAngel.LowATO.IsActive);
The code won't verify with your suggestion above.
sketch_nov24b.cpp: In function 'void loop()':
sketch_nov24b:72: error: could not convert 'ReefAngel.ReefAngelClass::LowATO.RA_ATOLowClass::IsActive' to 'bool'
sketch_nov24b:72: error: in argument to unary !
Any ideas?
Any ideas?
AJ
AJ
rimai wrote:For this purpose, you can mount whichever way you wish.
Use this for A:Or this for B:Code: Select all
Then, you can set the portal to alert you using the ATOLOW as a trigger.Code: Select all
change it to this:aspec wrote:Roberto,
Any ideas?
ReefAngel.Relay.Set(Port1,ReefAngel.LowATO.IsActive() );
Sent from my Nexus 7
